Need help: Whats this knocking! Video inside…
Discussion in 'Gen 3 Prius Main Forum' started by BrianStranded, Jan 17, 2024.
  1. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    2011 Prius with knocking sound. No check engine codes, nothing showing up on scanner. So far we have tried the following:
    1. The headgasket, timing chain, and rod bearings were replaced.
    2. The egr was cleaned to like new. The sound continues when the egr is unplugged.
    3. The knocking speed rate increases with the rpm.
    4. No metal shavings anywhere when the engine was disassembled.
    I recorded the noise, heres the link:
    https://youtube.com/shorts/ow3uRC9tiIM?si=rscE5xr3hwtQIT1G
    Any ideas what this could be? How can I diagnose where the noise is coming from? What else do I look for?
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    The normal sewing machine sound of a Prius engine is much louder in this one. I'm thinking something didn't get addressed with your valve train during the rebuild.
    BrianStranded likes this.
  3. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    Diagnosing where the sound is coming from:
    An old mechanics's trick is to use a long-handled screwdriver as a sound probe. Put the tip of the screwdriver at various places, and monitor the vibrations at the handle with your hand (or ear). In the case of an old-fashioned engine, if you suspect bad bearings in the alternator, probe the alternator. If the vibrations in the handle don't correspond to the noise, it's (probably) not the alternator - probe the power steering, A/C compressor, water pump, whatever.
  4. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    The sound looks like it's similar to mine and I didn't do anything to the valve train I just replaced the engine and it was rock solid steady quiet for close to a year and then this my eyes and my video go right in between the engine and the transmission You seem to be sitting up in the front with the camera a lot Is there a reason for that It looks like your engine is running dead set solid smooth notice when the clicking is going on the engine's not bouncing around this is exactly what I have right now I have no idea another guy on here disconnected the EGR and the noise went away a similar type of noise I didn't work on my car I'm thinking I've got to pull the transmission out and check the springs on the torque plate or see that the torque plate flywheel section thereof is bolted securely to the crankshaft or something My eyes are drawn right to the mating points of the engine and transmission in my video yours seem to want to go to cylinder number one or the right side of the car but it doesn't look like seemingly that's where the noise is emanating from.
  5. PriusCamper
    13,452
    5,430
    It is true that the dampener will fail if you live with a rough running bad headgasket for a while but not sure how a bad dampener would make a noise that matches engine RPM?
  6. BrianStranded
    118
    84
    New Orleans, LA
    I was thinking the same. It doesn’t sound like a knock per se, but a valve train thing…like a louder normal sound. But I can’t isolate it and its frustrating the hell out of me.
  7. Tombukt2
    13,855
    2,516
    Durham NC
    Sticking things in a valve train will often make that kind of noise as they catch up when they don't need to if you will and they make that clacking noise that gets faster with the faster you read the engine That's why mine noise is a little different because it doesn't really get faster and it doesn't seem like it's in the valve train at all where this one that's quite possible.
  8. PriusCamper
    13,452
    5,430
    Probably pulling the valve cover and slowly rotating the engine would help you figure it out. Or just live with it until something breaks, which is the easiest way to find out, but probably more expensive to repair.
  9. BrianStranded
    118
    84
    New Orleans, LA
  10. ChapmanF
    19,015
    The hydraulic adjusters are supplied with oil, so even if they were installed without it, they shouldn't stay that way.
    They contain little check valves that are supposed to keep them from losing oil too quickly; the repair manual shows a way of testing them.
    Toyota Service Information and Where To Find It | PriusChat
  11. BrianStranded
    118
    84
    New Orleans, LA
    Thank you kind sir, I get my lifters in Tuesday, I’ll report back to help other ppl with similar noise. If you have the pdf of the repair please drop a link
  12. Mendel Leisk
    42,338
    Last link in my signature has the entire engine section. Pretty sure the lifter test is in there, somewhere.
  13. BrianStranded
    118
    84
    New Orleans, LA
    Thank you Prius God
    I will update on the fix
  14. Danno5060
    405
    209
    Wyoming
    I saw this recently, and it made me think of this thread
    PriusCamper likes this.
  15. BrianStranded
    118
    84
    New Orleans, LA
    Im confident this isnt my issue. Thats not the sound its making. My timing chain is new and my chain guide is undamaged.
    I put the 16 new lash adjusters in last night, Im gonna button it up tomorrow morning before work and pray to all the gods that fixes the issue.
    PriusCamper and Danno5060 like this.
  16. BrianStranded
    118
    84
    New Orleans, LA
  17. Danno5060
    405
    209
    Wyoming
    Yikes!
    You're having way too much "fun" with this.
  18. Mendel Leisk
    42,338
    Any ideas as to why it broke? Torque spec is 20 lb/ft for those; see last link in my signature.
  19. BrianStranded
    118
    84
    New Orleans, LA
    No idea, I had it set to 20 lb/ft. Maybe they werent supposed to be reused? How bad is it if I just leave it in there broken…
    **edit*
    I torqued them to 27 lb/ft, thats what the repair manual says!
    #19 BrianStranded, Jan 25, 2024
  20. BrianStranded
    118
    84
    New Orleans, LA
