Need help where does this piece go?
Discussion in 'Gen 3 Prius Technical Discussion' started by Elytx44, May 5, 2024.
  1. Elytx44
    Elytx44 New Member
    Need help figuring out where this part goes.
  2. PriusCamper
    PriusCamper Senior Member
    13,432
    5,422
    Pacific Northwest, USA
    In Gen2 Prius It's a spacer that goes between front bumper cover and where radiator mounts... Seems the Gen3 one looks slightly different. If you look for a blow up diagram of parts in that area of the car you can see it's exact placement.
    Once an old Prius gets beat up enough they're problematic to keep in place and no harm in not putting it back, unless maybe if you live in really hot weather, in which case the radiator might be slightly less efficient.
    Elytx44 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,837
    2,514
    Durham NC
    In a gen 3 that goes up in the wiper tray If you look at your breakdown you'll see where it goes I think they might be two of them I have the wiper tray out of one right now It's probably never going back in and there's two little plastic pieces on each end of the wiper tray cover also but that's on the top plastic this goes inside separating the area where the wiper motor is from where water and debris might fall That's two little spaces where it clicks in look carefully you'll get it turn it around and you'll see.
    Carall, Elytx44 and Mendel Leisk like this.
  4. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    In between the metal wiper tray and the plastic cowl cover toward the passenger side.
    Here's a video where they pull off the entire cover. I believe that part is near the passenger-side hood hinge. There's a similar part near the wiper motor, but that one has a hinge in the middle.
    You may be able to get to where it goes without pulling off the windshield wipers.
    Try pulling the plastic cowl cover extension on the passenger side first. Then pop out the plastic clips built into the forward edge. Hopefully you can pull the plastic cowl cover far enough forward don't he passenger side to get to where that goes.
    Elytx44 likes this.
  5. Mendel Leisk
    42,307
    Roccobro and Danno5060 like this.
