Need help with a part...part 2
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ZeroDigit, Jun 11, 2018.
  1. ZeroDigit
    ZeroDigit Junior Member
    23
    Iowa
    So below my 2008 Prius, I noticed these hanging lower than they should. I looked around and felt in there that it feels like something I can nut and bolt back up. Can anyone help me locate the correct part or parts to fix this ? Is this something that is needed or should I just... pull it off ?
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Mine was loosened at the driver side from the front. Driving at highway the air pressed it down to the ground grinding off about 20% of its length.
    I simply replaced the part with a used one.
    Originally there are some different kind of plastic nuts, but
    -> you can simply fix it with some nuts and perhaps some additional washers.
    (At the bottom of the car are some threaded bolts.)
    ZeroDigit likes this.
  3. ZeroDigit
    23
    Iowa
    Oh ! Okay do you happen to know what size I would need ?
  4. MickyMatter
    260
    168
    Germany
    M6 nuts (metric 6mm regular thread).
    I've used some self locking (with a polymer ring) nuts made of stainless steel.
    SFO and ZeroDigit like this.
  5. ZeroDigit
    23
    Iowa
    Thank you so much ! I'm going to grab some tonight to get that fixed asap :D I'll post results tomorrow !
    MickyMatter likes this.
  6. ZeroDigit
    23
    Iowa
    So I went under last night to work on the covers. It looks like I'm pretty much SOL unless I wanna replace the entire part itself. I looked to see if there was any further places I can attach a nut and bolt and sadly there wasn't other than the few places that were already covered.
    Guess I gotta find the part to replace them. So if anyone has any idea what part # it is I would greatly appreciate it.
    Gen 2 prius : passenger and driver side underbelly covers near the doors.
  7. Mendel Leisk
    42,369
    ITBland, Raytheeagle and ZeroDigit like this.
  8. ZeroDigit
    23
    Iowa
    OMFG You are literally the best ! This is exactly the kind of diagram I was looking for, this is perfect ! Thank you !
  9. Mendel Leisk
    42,369
    Just remember McGeorge Toyota Parts. I can't even get them to ship up here, but a good info resource.
    ITBland and ZeroDigit like this.
  10. ZeroDigit
    23
    Iowa
    Well good news ! My folks I work with helped me solve my issue in a quick and easy/cheap way !
    3$ got me 20 extreme weather zip ties ( up to 185*F and -40*F). I ended up finding a great way to keep both ends up and out of the way.
    Here's what it looks like, it was done to both ends on both sides.
