Need help with a plug (how to unclip) electric inverter compressor
Discussion in 'Gen 3 Prius Technical Discussion' started by Warelan, Mar 22, 2024.
  1. Warelan
    Warelan New Member
    17
    Kansas City
    I am having trouble unclipping this given clip. I am sure it is easy once you understand what needs to be done - I am not sure if it is stuck or if I am doing it incorrectly. My guess would be the little oragne depression between the gray/green tab should slide down and/or go down and then they can be unclipped.
    This is on the 2015 connects to the eletric onverter compressor
  2. amarino
    amarino Active Member
    146
    107
    99
    Here is the section from the Techinfo. It looks like you slide the green piece out to unlock it.
  3. Warelan
    Warelan New Member
    17
    Kansas City
    Thank you very much
    amarino likes this.
  4. Warelan
    Warelan New Member
    17
    Kansas City
    It didn't come appart easily once the green latch was removed however there is enough room once that is out you can stick a screw driver up in the other end it will then lift the tab and allow it to unlock the latch. That wasn't possible prior due to a piece of plastic holding it down with the green tab... I just wanted to follow up as I am sure someone else will have the same question possibly in the future.
    Thanks again!
    amarino likes this.
