Need help with Autel KM100 on 2017 Prius - How to get the PIN code?
Discussion in 'Gen 4 Prius Main Forum' started by Alyssa L, Jun 8, 2026.
  1. Alyssa L
    Alyssa L New Member
    Los Angeles
    Hi everyone,
    I recently lost one of my key fobs for my 2017 Toyota Prius and need to program a new spare. I bought an Autel MaxiIM KM100 for the job, but I've run into a bit of a roadblock.
    When I tried to program the new key, the device asked for a PIN code (or outcode/incode). I'm a bit stuck here—how or where can I get this PIN code? Does the KM100 have a built-in function to bypass/calculate it for this year, or do I need to get it from a third-party service?
    If anyone has successfully programmed a smart key for this generation using the KM100, I would greatly appreciate any tips or step-by-step advice!
    Thanks in advance!
  2. JC91006
    16,936
    8,647
    You probably need a seed code or passcode to make a key. Requires your vin.
    There are 3rd parties that can provide that. It’s suppose to be secure method so people can’t make keys with ease. I have a friend in the Los Angeles area that can help you with making the key or maybe he'll sell you one of these codes if you want to attempt it yourself
    #2 JC91006, Jun 8, 2026
  3. Alyssa L
    Alyssa L New Member
    Los Angeles
    Thanks for your help! I did some research yesterday and found a way to bypass this step, so I don't need any further assistance at the moment. Much appreciated!
  4. JC91006
    16,936
    8,647
    You want to share your new found bypass?
  5. Alyssa L
    Alyssa L New Member
    Los Angeles
    I’m still using the Autel KM100, but I tried a different approach. I watched a few YouTube videos and read some articles, and found a method that worked for me. Instead of going through the usual PIN process, I accessed it via the keyless system and backed up the IMMO data first. After that, I was able to generate the key without needing the PIN.
    It worked successfully on my side, so it might be worth looking into.
    JC91006 likes this.
