Need Help with Cold Weather Start
Discussion in 'Gen 3 Prius Main Forum' started by Tuvshinbayar, Dec 25, 2023.
  1. Tuvshinbayar
    Tuvshinbayar New Member
    Mongolia, Darkhan
    My car did not working recently because here is 35C cold weather so, did you know how to turn my car on could you all help me
  2. Mendel Leisk
    42,341
    I’m sure you mean -35C?
    Was it starting ok on previous days?
    Does the car have the “block heater”, that you can plug in prior to starting, an electrical heater to warm up the engine coolant prior to attempting to start the car?
    I’d start by checking the voltage of the 12 volt battery, preferably with a meter having a digital display. A completely healthy battery will be at least 12.6, 12.0~12.6 would be weak but maybe enough for car to start, and if lower than that it would be best to replace it.
