Need help with FlyAudio Nav install with JBL
Discussion in 'Gen 3 Prius Audio and Electronics' started by J0keboy, Dec 16, 2011.
  1. Bulle
    Bulle Member
    378
    49
    I read that report too somewhere else but mine was working perfectly.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I suspect something got unplugged during the install. Now you need to open up the dash and check the wiring. I found it was not a good idea to press the start button until everything was reattached. When I did that The "check hybrid system" message popped up.
    Good Luck with your latest problem.
  3. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    What is not functioning? Is climate display okay? The HU replacement has nothing to do with AC control for non-NAV levels. Check the connectors around shift lever, maybe the connectors are not plugged firmly.
  4. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    how come my flyaudio unit doesn't have the green backlit for the buttons
  5. ucsmfu
    1,498
    420
    canada
    jokeboy, hey how did you get the igo gps to work ?
  6. J0keboy
    J0keboy Junior Member
    Falls church
    Sorry, I've been busy... did you figure it out yet?
    If not, message me.
