Need help with install the front shock.
Discussion in 'Gen 3 Prius Main Forum' started by ilhouhou, Mar 14, 2024.
  1. ilhouhou
    ilhouhou Junior Member
    39
    Uk
    Hi Guys,
    I'm trying to replace the front shock for my 2010 gen 3 prius.
    But came into this issue in the end. The sway bar looks like higher than the hole on the shock, did I do something wrong? Someone help me please.
    Thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    13,626
    2,468
    Durham NC
    Raise the car at jack.point in front of door at rocker panel?. Wen it aligns put in hole add nut.?
  3. ilhouhou
    39
    Uk
    Yes I raised the car at the rocker panel. for some reason, it just wont match that socket hole. You can see in the picture, the bottom two 22MM sockets are all in the right place. The shock I'm using is KYB G excel. 339242 is for the right side, and 339243 is for the left. I'm in the UK BTW.
  4. Tombukt2
    13,626
    2,468
    Durham NC
    All I'm saying is if you lay the strut tube down on the floor next to the original those tabs are in the same place on both of the shocks the one you took off the car and the one you're trying to put on I can't see from here usually I believe you've got to let the lower control arm go down a little further so the stuff will line up .
  5. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Raise the other side of the car too.
    james wang 20 and ilhouhou like this.
  6. ilhouhou
    39
    Uk
    Thanks Tombukt2.
    I have compared the KYB one with the original strut, it's the same size. Do I have to lift both left and right side of the car up when doing this job?
  7. ilhouhou
    39
    Uk
    Oh man, you probably saved my day. I will try that first thing tomorrow morning and keep you posted.
    #7 ilhouhou, Mar 14, 2024
  8. ASRDogman
    ASRDogman Senior Member
    7,901
    4,018
    You only have to raise one side at a time.
    You might want to loosen the axel nut so it will slide.
    You might pop the cv joint off the axel when you remove the strut and
    the assembly falls over. Brain fart on the part name....
  9. ilhouhou
    39
    Uk
    Thanks for the info. If I knew this could happen, I would not try to do this job in my garage. Do you think I should ask for a mechanic to come over and fix it?
  10. ASRDogman
    7,901
    4,018
    You can do this, it's really easy....
    When you remove the two bolts, Don't let the arm just fall, just slowly move it
    until it just lays there. Don't panic on this stuff. Take your time.
    ilhouhou likes this.
  11. Tombukt2
    13,626
    2,468
    Durham NC
    It's a real easy job it's kind of like a puzzle you'll get it in a few minutes in a few tries and you'll be very satisfied when you do this is actually generally a very easy job once you get it you'll be amazed I guess.
  12. amarino
    amarino Active Member
    143
    105
    99
    I've done this with my old BMWs when working one side at at time in a cramped single car garage. Rest the car on a jack stand. Then use the jack under the front strut/shock with a piece of wood and very slowly jack up the strut (this compresses the spring, so go slow) straight up until the holes align. Then after you get it tightened slowly release the jack.
  13. ilhouhou
    39
    Uk
    Appreciate your help, mate, I have to raise both sides to put the sway bar in there.
  14. ilhouhou
    39
    Uk
    Thanks
    Thanks to all. Finally put the tires back on, road test it and works fine. I guess I need to get the alignment job done now.
    Tombukt2 likes this.
  15. Tombukt2
    13,626
    2,468
    Durham NC
    Generally if you put the struts on correctly and you've not moved the adjustments on the tie rods and when you put the two bolts in that attach the hub to the strut bottom if you push in on that assembly and tighten those two bolts you should be back where you started when you took the car apart that's a fact My alignment guy tells me all the time when I take him a car after I put the struts on no Tom you don't need an alignment You know as well as I do every time you do this you're within a 16th of an inch of where you were when you took the car apart we've gone over this and over this many times before and that's just how it works out so unless you're really sloppy and don't know any better or what have you You're alignment will be where it was when you took it apart if you reassemble it just like you took it apart You shouldn't be moving tie rod ends the adjustments or any of that right? Think about it so when you go to get your alignment if you're alignments off more than likely it'll be a slight bit of camber because when you put the two bolts through the hub you just tightened them up rather than pushing in on the hub letting it clunk and blasting the bolts tight with your air gun or electric gun or whatever you're doing If you left the hub pushing out towards you when you're standing at it tightening it then you'll be off a few degree a degree and a half or so on your camber You're alignment guy will loosen those nuts push it down tighten the nuts look and see what the heads are telling him on the car but the wheel back on and send you on your way probably.
  16. ASRDogman
    7,901
    4,018
    You don't need an alignment. Unless you had issues before hand.
    There are no caster or camber adjustment, unless you purchase those speacial
    bolts to do a camber adjustment. Only the toe is adjustable. And if your tires
    are wearing evenly, no reason to touch them.
    Glad you were able to get them replaced. Fairly easy, right?
  17. ilhouhou
    39
    Uk
    Thanks for the explanation. Took me a while to understand, you are saying I dont have to do the alignment if the car is going straight. Right?
  18. ilhouhou
    39
    Uk
    Exactly, the other side is so easy after I complete one side. Thanks for your help again. Feels good that I learned new skills.
    ASRDogman likes this.
  19. ASRDogman
    7,901
    4,018
    If the car drives straight, and the tires are wearing evenly, you don't need an alignment.
    You also want to check the other parts. Control arm bushings, ball joints, sway bar links....
