Need Help With Locating Wire Colors For Power, Remote On and Rear Speakers from OEM Head Unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by msimmers, Oct 3, 2020.
  1. msimmers
    msimmers Junior Member
    Florence, AZ
    I have been searching and have had zero luck locating, what I thought, was an easy answer to my question. I have a 2013 Prius 4 w/ the JBL E7039 Head Unit. I am trying to find the wire colors for the power, remote turn on and rear speakers... coming out of the Head Unit, Not the JBL Amp. Any help would be greatly appreciated. Thank You in advance.
  2. msimmers
    Florence, AZ
    Anyone??? Anything???
  3. Tideland Prius
    16,155
    Renamed your thread so it's more descriptive. Hopefully that'll garner some more attention.
  4. ChapmanF
    15,622
    Do the rear speakers actually come out of the head unit and not the JBL amp?
    I'm not sure what you're after with "remote turn on".
    Has the wiring diagram (more info) not contained what you need?
  5. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "I'm not sure what you're after with "remote turn on""
    This generally addresses "Remote Turn-on Wire"
    msimmers likes this.
  6. msimmers
    Florence, AZ
    Thank You
  7. msimmers
    Florence, AZ
    All speaker leads should come out of the H/U and input to the amp. I need the non amplified leads to the rear speakers. LR and RR + and - I have figured out how to remotely turn on the Bazooka Tube.
  8. ChapmanF
    15,622
    Looking at a 2010 wiring diagram, going from the H/U to the amp there's just one balanced pair for right channel (green/black), one for left channel (red/white), and a digital AVC-LAN hookup (over wires that are also, sadly, green and red).
    I also don't see anything suggesting a discrete remote turn on signal. Perhaps there is an AVC-LAN command for that.
    I know there were major A/V changes in the 2012 refresh, so 2013 details could be different.
  9. msimmers
    Florence, AZ
    I'll take another look this weekend. I use the car M-F for work, so I don't have a lot of spare time to tear everything apart. Luckily...Toyota made this easy. You would think the wiring diagram would be around...somewhere ;-)
