need help with my prius
Discussion in 'Generation 1 Prius Discussion' started by needtoknow, Oct 27, 2010.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Good point Bob, but the OP stated that he charged the 12V. But never verified the actual readind.
  2. andyprius
    2,212
    188
    All very true. The OP states that he bought the car used. Possibly the 12V was never changed. Possibly the HV system is shot. If his HV battery is shot he may very likely be eligible for a brand new HV battery, FREE. Up until this point in time he may not know this. I still suspect his aux battery tho.:D
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    I missed that it only had 56K miles. The pessimist in me sees Gen I and immediately thinks expired warranty. What are the warranty terms for a 2001, assuming that it is a California car?
  4. andyprius
    2,212
    188
    On mine it is 150000 miles, I'm not sure of the time, 10 years I think...... for the 2001 it may be the same, if he doesn't delay.:rockon: Being in Socal, I assume it was bought in CA, or registered in CA, should qualify. It is great that the warranty is transferable to the new owner. Strange that he was not informed.
  5. Patrick Wong
    18,210
    6,517
    Classic Prius sold in the US has an 8 year / 100K mile hybrid system warranty. The longer hybrid warranty in CA (and like-minded states) started with the 2004 model year because 2G was certified AT-PZEV.
  6. andyprius
    2,212
    188
    Thankyou Pat, I can never keep that straight.
  7. andyprius
    2,212
    188
  8. needtoknow
    needtoknow New Member
    17
    socal
    2001 Prius
    hello...
    i have a new 12 v in there and the car is just out of warranty(my luck..lol)
    i am now going to start the car let it idle til it shuts the engine down.
    then disconnect the 12v and see if it still will drive solely on battery.
    thats what it looks like i am being asked to do from patrickwong.
    i also have the code 0171 coming up now....dont know what that is.
    the battery on the info screen seems to stay at full green charge...
    thanks again for all your help and anymore advice will surely help.
    thanks
  9. needtoknow
    17
    socal
    2001 Prius
    ran the car til it idle with engine off and unplugged the battery 12v negative and the engine turned back on when i hit the gas...so i am not sure how to run the car in just battery mode.
    i am now inspecting the main battery behind the seat to look for any anomaly in the banks....leakage..etc.
    thanks again
  10. bwilson4web
    16,516
    I think you are missing the big picture:
    • 12 V system - this powers the lights, displays and all control computers. It is separate from the traction battery but charged from a DC-to-DC converter in the inverter. If your car is running, the 12 V comes from the DC-to-DC converter so disconnecting the 12 V battery has no effect.
    • traction battery - this is a 270 V power system that can provide with the engine the "hybrid" in hybrid electric.
    If you still have errors on the car, to reset the error codes and find out if they come back:
    1. Turn off the car - remove the key. You want it in "P" and not in any way shape or form running.
    2. Disconnect the 12 V. battery negative from ground - this will remove the 12 V voltage that keeps the control computer memory alive. It will also clear any error codes PROVIDED the car is powered off and the key out of the car.
    3. Wait 3-5 minutes - this ensures any capacitors or other latent voltages sources are gone.
    4. Reconnect the 12 V. battery negative ground - this will allow the control computers to be in 'sustainer' mode. You may see some light sparks as the capacitors in the circuit charge up but this is normal and not always seen.
    5. Put the key in the ignition and turn to ACC mode - are there any errors indicated?
    6. Turn to IGNITION mode - are there any errors indicated?
    7. Turn to START and release - are there any errors indicated?
    8. Let car run for ~5 minutes in "P" and look for any error indications.
    9. Put car in "D" and drive - are there any errors indicated?
    This will let us know if the problem was a 'transient' or permanent. It does not diagnose the problem but let's us understand how severe.
    Get a scanner (see the other recent postings) to read out the codes and vehicle values. This is your gold standard for diagnosis of the car.
    FYI, you might upgrade your profile to give us an idea of where you live. Sometimes it helps so we can make sure our postings are clear and unambiguous. Also, there are folks on the forum who may live near with tools and resources to help.
    Thanks,
  11. needtoknow
    17
    socal
    2001 Prius
    thanks bob...greatly apreciated.
    if your referring to the trouble codes..they will come back on for certain as i have erased and ran the car several times to only have the codes come back.
    the codes are...
    3006
    3015
    and a pending 0171
    i am aware the 3015 is bank 5 in the HV battery.
    i also was getting a 3011 code but irt went away as the car was charging the battery as the car has sat for 8 months.
    i am now knee deep in the HV battery.
    i have removed the rear seat and now taking off the top battery panel to search for any leakage from any one of the banks.
    i have experience as an electrician so please dont worry about electrocution....lol
    if you have anymore advice i am checking on this thread every 30 minutes or so as i get the battery situation out of the way as process of elimination....
    then on to the next
    thanks again
  12. needtoknow
    17
    socal
    2001 Prius
    and oh yeah....
    i live in huntington beach california and its a hot one today.
    i wasnt thinking and i didnt park under shade and nolw i cant move the car now as its apart and unplugged.......doh!
  13. Patrick Wong
    18,210
    6,517
    I hope you know that you should remove the orange traction battery interlock as a safety measure, before you remove the traction battery cover.
    Once you have the cover off, use a digital multimeter to measure voltage on each of the 38 modules. Log your measurements. You'll probably find a couple of modules whose voltage is much below the others; those are the failed modules.
  14. andyprius
    2,212
    188
    I see you are really into it now, there are several threads on attacking the HV battery, replacing battery modules, replacing whole battery pack, replacing with a Gen I or Gen II pack, and lastly balancing individual modules. It would be well worth your while to relax one evening read these threads. Best sources are Bob Wilson, Pat and Vincent and of course Hobbitt. You can search by subject or click on a name. There are others who have also contributed to our knowledge. Working out on a parking spot will interfere a bit with order, if you can you may want to investigate the pack at your apartment.:cheer2:
  15. needtoknow
    17
    socal
    2001 Prius
    ok..
    thanks again.
    now i am going out to measure each bank individualy and recording the measurements.
    if there are some that are too low does that mean i have to replace battery completely?
    there are no batteries in my area except for the $2300 dealership price.
    i will respond shortly with battery results.
    thansk!:)
  16. needtoknow
    17
    socal
    2001 Prius
    ok...
    i just checked out each bank for voltage test.
    each on is the same roughly at 8.10 except for bank five which is a 6.7.
    the code that its shooting is 3015 which refers to bank 5 and it makes sence.
    now when i initially started messing with the car it had these codes..
    3006
    3011
    3015
    i drove the car and reset codes and it read these coders...
    3006
    3015
    and a pending 3006 code.
    so it leads me to believe that the car was recharging bank one and thats why it not there now because its charged.
    now if bank 5 is reading 6.7 is that too low?
    or what needs to be done to remedy?
    again...many thanks for your help
  17. Patrick Wong
    18,210
    6,517
    At minimum, you will need to replace the module that has the low voltage measurement, if you can buy a replacement. That should be considered a short-term fix, if you can get the replaced module to work.
    A longer-term fix is to replace the entire traction battery but of course that will cost into four-digits.
  18. bwilson4web
    16,516
    Patrick is right so your options:
    • Ebay kludge the modules - the problem is you don't know the Ahr capacity of the modules bought nor the Ahr capacity of the existing modules. User "oldnoah" did the job right but he had the option of the original failed battery and the replacement. Risky!
    • Rebuild using NHW11 modules - follow the "oldnoah" threads and think about the time and effort it took. As for the tools, especially the MRC 989, you could PM him to see what he might sell them for. This approach requires a lot of time, 20-40 hours; a good work area; and careful attention to detail. Reduces risk and leads to a quality product. You'll need high technical skills.
    • Rebuild using NHW20 modules - instead of buying NHW11 modules (or a 'pig in poke' pack), buy two salvage, NHW20 packs and then follow "oldnoah" processes . . . Done right, a quality product. Requires high technical skills.
    • Buy Re-InVolt - ~$1,700, the pack is already rebuilt from tested modules and improved internal wiring. Two people in four hours can swap the pack and you're on the road again.
    • Toyota self-build option - ~$2,400, you get a fully populated case of modules and move the electronics over. Then install and run.
    • Toyota total option - battery plus labor, easily ~$3,000.
    GOOD LUCK!
  19. needtoknow
    17
    socal
    2001 Prius
    so seeing the code for bank one dissapear would it be reasonable to say if i was to drive it a bit the 5th bank would eventualy get from 6.7 to 8.1 amps?
    i only drove the car for a day for the bank 1 error code to go away.
    seems like it could be such an easier solution rather than replace the whole thing or taking out the complete module or 5th bank.
    or a way to charge the 5th bank individually in some way as just a quick fix.
    i just want this car to pass smog test and then the light can come back on for all i care down the road.
    its funny how i cant get the car registered or pass smog because the check engine light is on and this car still works and is functional but a faulty bank....and its not polluting anymore than it would if the light was off.
    kinda lame i have to spend atleast $1500 or just spend 40 hours to remove faulty bank.
    very frustrating.....
    if anyone has a quick fix idea i am all ears.
    otherwise i guess its time to kneel to the dealership god.
    thanks again for the help
  20. Patrick Wong
    18,210
    6,517
    I doubt that the one module will recover. It is likely that one cell within that module has shorted, this is why the voltage is so low.
    Bob has done a good job of summarizing the various alternatives. Note that you may be able to purchase a new traction battery for ~$1,750 plus shipping. See for example:
    Champion ToyotaWorld
    and look up the price for G9510-47020.
    If you do not fix the traction battery, eventually the car will get to the point where it will not start (since the traction battery spins MG1 to start the engine.) Good luck.
