Need help with replacing the head unit with Android one
Discussion in 'Gen 3 Prius Main Forum' started by Ohioprius, Feb 29, 2020.
Tags:
  1. Ohioprius
    Ohioprius Junior Member
    Bowling Green, Ohio
    I'm trying to replace my 2015 Toyota Prius Model 3 Head Unit with a 10.2 Inch Dasaita Android unit. There are two cables that I don't know what they are for.
    [​IMG] https://photos.app.goo.gl/g6CRbJzcRiLM7qdR8
    Can someone tell me what these are for?
    Regards,
    Jeff
  2. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    If I recall correctly, One of them is for the am/fm antenna. You will need to buy an adapter to convert it to a conventional styled antenna plug. I think the other is the antenna connection for the satellite radio.
  3. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    I guess I did not recall correctly, the antenna connector is a rectangular white one. My GUESS is those cables will not be used by the new android system. There were a couple that were not re used when installing my system several years ago. I still think one MIGHT be for the Satellite antenna.
    Ohioprius likes this.
  4. Ohioprius
    Bowling Green, Ohio
    I have the unit installed. I'm in the process of configuring the unit now. Thanks for the help.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Would love to see pictures of it when done.
  6. Karolis
    Karolis Junior Member
    Vilnius, LTU
    One is Sirius XM connector; the other is for GPS antenna. Both won't be needed.
    I've just finished installing a Sinosmart branded Android HU with a 9" QLED screen. It was NOT plug and play for me (steering wheel controls and backup camera didn't work at first), but got everything sorted eventually.
    All things considered, I'm extremely happy with the purchase.
  7. Ohioprius
    Bowling Green, Ohio
  8. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    OooOoOo looks nice & clean. For the USB ports, just buy one of those 2 port usb instrument panel ones and pull the cigarette lighter plug plastic panel toward you. Disconnect the lighter connector and cut a rectangle hole and mount the usb instrumental panel port in the rectangle hole. Use one of those 'add a fuse' wires and power up the usb port but make sure the voltage is regulated to 5v or 3.3v as needed.
    Montgomery likes this.
  9. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    I was able to find a direct fit snap in 2 port usb conection and charging port that I plugged in under the tunnel. When I finally got around to hooking up the wire for the charging feature, I hooked it to a live 12 volt fuse that keeps that port charging even with the car shut down.
    I tried going back thru my emails but could not find it. Pretty sure it was bought on ebay. Careful though as Toyota apparently has 2 sizes of those knock outs that they used. I had to order a second plug that fit.
  10. kc5dlo
    266
    164
    DFW TX
    2021 Prius
  11. TwinPrius
    TwinPrius Junior Member
    Northern Virginia
    Hi I am about to purchase the same Dasaita 10 inch. Can you please tell me what else do I need to buy to make it work with my gen 3 prius too. Canbus, mounts or other cables I need. I have oem nav, jbl and rear camera.
    Thank you!
  12. Michelg2
    Michelg2 New Member
    Hello,
    Can somebody help me with this:
    I'm about to buy the same head unit, but before I would like to make sure of some things, I appreciate if you could help me with the following questions:
    Can I keep original back up camera and avoid installing a new one with all the headache of cables? How did you manage to kee your original camera?
    Will I keep the car performance menu like the OEM head unit? I would like to maintain the possibility to see my consumption and battery energy flow.
    Thank you in advance.
