Need help with wheels and tire sizing
Discussion in 'Gen 5 Prius Accessories and Modifications' started by MR2_VC, Jul 3, 2024.
  1. MR2_VC
    MR2_VC New Member
    califorina
    2023 Prius
    So im planning on getting new rims 18x9.5 +35
    does know know if i get tires size 225 or 235/35 or 40/18
    will it clear lock to lock when steering and will these sizes have any rubbing issues?
  2. Eddie F
    Eddie F Junior Member
    28
    Windsor, Canada
    2024 Prius Prime
    SE
  3. Neilwade
    Neilwade New Member
    Netherlands
    For your 18x9.5 +35 rims, 225/35/18 and 235/35/18 tires might be too narrow, potentially causing a stretch. The 225/40/18 or 235/40/18 tires are better options, but they might increase the overall diameter. With a +35 offset, the rims will sit relatively flush, but you should test-fit to ensure no rubbing during full lock-to-lock steering. If your vehicle is lowered, the taller tires could potentially rub. Consulting a professional tire and wheel shop for specific advice is recommended.
  4. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    I went with 225/55/17 on 17x7 and it's a perfect fit.
    Fills the wheel well nicely.
    thetoys likes this.
  5. Juju2
    Juju2 Junior Member
    Bozrah
    How are they fairing now? Just wondering if you had any issues since then that you could share I have a 23 Prime and looking to get some winter tires on the OEM 17” wheels .TIA!
  6. Blackat
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    These are my summer set up. Still great, no issues since day 1.
    I have another set for winter, 16" wheels running Bridgestone Blizzaks 205/65/16
    Also, perfect
  7. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    I've got the standard 195/60/17's on my car and I really like the ride, maybe a little bit hard.
    Can't imagine it on 35 profile tyres.....
  8. NJW
    NJW Junior Member
    17
    Philadelphia
    2024 Prius Prime
    XSE Premium
    I have 235/45R18's mounted on 18x8 Sport Edition wheels, offset of which I don't know. They were the winter set off of my Model 3. Zero fitment issues after 2,000 miles. The tech at Costco, where I have an appointment Tuesday to mount a set of Crossclimate2's was skeptical that the 225/50R18's would fit. I mentioned TireRack's confidence that they would fit and the fact that I'm currently running on wider tires, but he said they use tighter specifications and that call would have to be made by the Supervisor. I found it annoying that they couldn't discuss where those specs came from while TireRack specified that they do a 3D scan and were confident the set I already had would work.
  9. Juju2
    Juju2 Junior Member
    Bozrah
    Update , I ended up just getting the Michelin Ice X 195/60/R17 (pricey)on the OEM wheels. So far so good no road noise, wondering what the MPG will be now they are mounted on. I didn’t want to mess around so I stuck with the factory size unfortunately this is the only option right now for a winter tire.
    Perfectpacman likes this.
  10. Perfectpacman
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Interesting about the drop in road noise.
    I actually prefer the larger profile tyre. Always had bigger wheels and low profile tyres and I'm done with damage from kerbs etc.
    I do wish though manufacturers would consider just a little more about cabin noise. It wouldn't be expensive to have just a little thicker insulation around the arches etc.
  11. Mendel Leisk
    42,341
    The ones that came with the car, or extra? Extra rims, in other words two complete, ready-to-install sets of tires-on-rims, is advantageous for a lot of reasons.
    And a very good option. (y)
  12. Juju2
    Juju2 Junior Member
    Bozrah
    I ended up going with the Michelin Ice X 195/60/R17 on OEM 17” rims so far so good . What wheels can I mount the factory Toyos on ? Do older generation Prius wheels work for the Toyo Extensa A/S tires for me to mount them on?
