1. B.H.
    B.H. New Member
    I just bought a 2004 prius with 187000 miles for $2,500 and
    it has a triangle with an exclamation point in it and check engine light on and another symbol on the dash.When I take off it revs like the transmission is slipping and it only will get up to about 50 mph.Do you think I got beat on price and I would appreciate info from anyone that has experienced similar problems or has knowledge about these issues.
    Thanks in advance.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Do the symptoms you described happen immediately or after a few minutes? The problem you are describing could be a failed inverter pump, (a long shot, but possible) which you can check by turning the car on and looking in the inverter coolant tank for turbulence. Or, more likely, a failing traction battery (the big one in the trunk) which can be replaced by Toyota (over $4000.00), replaced with a battery from Reinvolt ($2,000 or less), rebuilt by you using replacement batteries (patience necessary, but relatively inexpensive). The third issue it could be is a failing Transaxle which contains two electric motors referred to as MG1 & MG2. If it is the transaxle, it could be replaced new (again around $4,000) or swapped out with one from a junked Prius (around $2,000 installed.)
    Of course, there are other things that can cause it, but the above listed items are most likely where the problem is. I would recommend using a Prius Aware Scanner to get the codes stored in the computer as they will help determine the exact cause of the error. Going to a place like AutoZone may give you a generic code, but it will not be able to read the Prius Codes relating to battery charge, etc.
    There are many people here that could help, but the codes are paramount to determine the problem!
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Sounds like an hv battery problem to me but, you have to get the codes read like Eclipse said. You didn't get taken because you only paid 2500 for the car.
  4. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    What is the best scanner to get without spending a ton of money and that's user-friendly? Where is the best place to buy it?
  5. Eclipse1701d
    645
    224
    Three Touring
    The most used scanner on PriusChat is the ScanGauge II. It can be purchased via the PriusChat Store.
  6. greasemonkey007
    287
    106
    Thanks. I hope I won't need it for a long, long time. I'm getting ready to put my battery pack back in after changing a couple of mods. Got my fingers crossed.
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    "Best" is a relative term. I would opt for the mini VCI on eBay if you want complete diagnostics for repair work, and it's cheap. The ScanGuage is more for continuous use in monitoring selected values while driving.
    Britprius likes this.
  8. greasemonkey007
    287
    106
    Thanks. Will it read all the factory codes or just the generic ones?
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    It will read all the codes. It is a pirated copy of what Toyota Technicians use.
  10. B.H.
    B.H. New Member
  11. B.H.
    B.H. New Member
  12. B.H.
    B.H. New Member
    I've been driving the car all week.Sometimes it acts up immediately and some times I can go 10 to 20 miles before it acts up.I discovered that I can pull over and power off the car and power back on and it drives normal for a couple of miles up to 20 miles.There is a symbol of a car with an exclamation point in the center of the car that stays on in the screen,when it starts acting up a symbol of a battery that says main comes up on screen most of the time,but not always,I checked those symbols and they point towards the hybrid battery.I also had codes ran at Autozone and every code points to a bad hybrid battery.I called Toyota dealer and give them the codes and they said all codes are pointing to a bad hybrid battery as well.I talked to remanufactured battery companies and a hybrid technician and they all said the symptoms are symtoms of a bad battery.So,I have been checking around for salvage yards and have found several batteries and they all run around $1,000.So I think that's the route I'm going.I found a salvage yard that only has a $15 core charge,so I'm going to keep my bad battery and check into rebuilding it or sell it to a reman. co.​
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,838
    Clearwater, Florida
    Why aren't you posting those codes here? We are usually more accurate then the dealer.
    Auto zone won't be able to read Hybrid Codes off this car. Need a higher level tool for that. Dealer uses Techstream software on laptop.
    Easiest and fastest and most accurate method is take it to the dealer and spend $125 diagnostic fee and have all the codes pulled including the subset number and post them back here before buying anything. It may need an Inverter which sometimes appears as a bad battery.
    Code will look like this for instance with a 3 digit subset:
    P3000-123
    But first while at dealer see if they'll print out the Vin based database on the car repair history at the dealer.
    This database is Toyota.com/owners.
    You'll probably see where some Toy dealer looked at it and it had many P3000 nags and the owner dumped it and traded it in. Then you know for sure if its the battery.
    You can join that site for free but not sure if you will be able to see that car's original history yourself as your a new owner and not original member/owner of that vin. May have to use dealer admin for that.
    The site is free to join.
    Try it. Join and see what comes up on that vin.
  14. B.H.
    B.H. New Member
    The codes are P0A80,P3014,P3021,P3022,P3030
  15. nh7o
    1,686
    340
    Hawaii
    Those codes are for failing HV battery. Blocks 4, 11,12 are weak. All consistent with your symptoms, and not surprising given the mileage. Your options are to replace with new (costly), rebuild and rebalance with replacement modules (cheap but takes time), get a rebuilt battery complete (more expensive than DIY), or find a salvage battery (rare now). Where are you located?
    uart likes this.
  16. B.H.
    B.H. New Member
    Thanks for the info..I'm located in Tennessee.
  17. nh7o
    1,686
    340
    Hawaii
  18. B.H.
    B.H. New Member
    I bought a battery pack for $1,064.58 from a salvage yard,installed it myself and the car is running great,all the warning lights are off.Now I'm ready to see what kind of gas mileage I get out of it.I appreciate all the info. I received from everyone it was very helpful.
    usnavystgc and nh7o like this.
