Need inverter after just under 50k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KTA22, Jun 16, 2020.
  1. KTA22
    KTA22 New Member
    I have a 2012 Prius with just under 50,000 miles (I work pretty close to home). I took it in for 50k service, and the day after the that I was out and got the dreaded “check hybrid” warning and my car basically had no power. I took it to my independent auto shop and he told me it needs a new inverter, which will be $1600. Is this common this early on? I know it’s an older car, but I’ve always serviced it regularly and only drive it about 6,000 miles a year. For it to need this much after 50k makes me wonder if I want to buy another hybrid - or another Toyota for that matter. I don’t really trust their longevity. Any thoughts?
  2. Air_Boss
    Air_Boss Senior Member
    4,244
    1,194
    New Yawk
    Have you determined whether there are any open recalls or TSBs for the inverter? Prius inverter-motor-generators have had several campaigns.
    Raytheeagle, mjoo and Mendel Leisk like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,971
    6,881
    Texas Hill Country
    The biggest mistake is asking an independent to fix it before checking with Toyota. One of the inverter recalls:
    • Recall Number
      14V053000
      Recall Date
      02/12/2014
      Component
      HYBRID PROPULSION SYSTEM: INVERTER
      Summary
      Toyota is recalling certain model year 2010 through 2014 Prius vehicles. In the affected vehicles, the Intelligent Power Module (IPM) inside the inverter module (a component of the hybrid system) contains transistors that may become damaged from high operating temperatures. If this occurs, various warning lamps will be illuminated on the instrument panel and the vehicle will have reduced power allowing it to only drive a short distance.
      Consequence
      The vehicle may enter a fail-safe/limp-home mode that limits the drivability of the vehicle. The hybrid system could also shut down completely resulting in a vehicle stall, increasing the risk of a crash.
      What Owners Should Do
      Toyota will notify owners and dealers will update the software for both the motor/generator control electronic control unit (ECU) and the hybrid control ECU, free of charge. If an owner experiences a failure of the inverter before the vehicle receives updated software, the dealer will repair or replace the inverter assembly with a new one at no charge. The recall began on March 21, 2014. Owners may contact Toyota at 1-800-331-4331.
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
  5. KTA22
    KTA22 New Member
    Yeah, my mechanic pays to have his system linked to Toyota, and it came back with no recalls for my car for this problem. He caught a different problem I had years ago with my Camry, so I assume it would catch it for this as well.
    I am the original owner, and I don't remember getting a recall about this specific issue, but any time I did get a recall notice I took it in to have it taken care of.
    I also went to the Toyota website and entered my VIN, and it says "there are no open Safety Recalls or Service Campaigns for this vehicle." So I assume he is correct in stating that this would not be something covered by that recall.
  6. bisco
    52,758
    it's extremely uncommon, and you cab buy a salvage inverter for a hundred bucks, because no one needs one. maybe try a dealer, might be worth the investment
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    New PC trend- CEL codes are just a suggestion.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    There is a separate warranty extension for the inverter depending on the fault codes found. I would have the dealer look at the car.
    Mendel Leisk and Raytheeagle like this.
  9. borgestes
    borgestes Member
    89
    76
    New York
    Mine went out in one of my 2010 cars. I got a inverter off ebay for 200 bucks and installed it in an hour. Drained the coolant into a bucket and poured it back in. Been driving it ever since and that has been a couple years ago. I think mine was the 12 volt converter, I knew about the recall but for 200 bucks I just swapped it out. Easier than a maybe from the dealer.
