1. David Kleinwolterink
    David Kleinwolterink Junior Member
    26
    iowa
    We bought an 05 with side damage all fixed put 2 new doors and side post ,painted looks great only (75 K miles )
    But now the head lights dont go off when you open drivers door opens and dome light as well ,
    thanks in advance for your help
  2. JC91006
    16,936
    8,647
    Drivers light doesn't go off when you open door
  3. David Kleinwolterink
    26
    iowa
    yes headlight ect
  4. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Remove the drivers door pin switch and see if the is functioning correctly. Do a continuity test on it too.
    Hope you didn't pay much for the car.
    wrprice likes this.
  5. Mendel Leisk
    42,355
    This is confusing the heck out of me, but I'm not a second gen owner, will stay out of it. (Do I hear applause?)
  6. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Dome light should turn on (if switch is in the DOOR mode) when the door is open, obviously. Also in US Gen2 models, if the headlight switch is left in the ON position then the headlights should auto-off when the driver door is opened after turning the car off.
    Both of these functions operating incorrectly is good reason to examine whether the driver door switch on the door jamb is functioning correctly.
    David Kleinwolterink likes this.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Might just be easier to turn off the headlights when exiting the car than fixing it, especially if its gonna be an expensive fix.
  8. David Kleinwolterink
    26
    iowa
    ooh for sure was throwing it out there if anyone had been in this fix ,thanks again
  9. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    It's the door switch
    iPhone ?
  10. David Kleinwolterink
    26
    iowa
    Yes its the Door switch !
    Thanks for the help
