Need new headlight bulb for an 07
Discussion in 'Gen 2 Prius Main Forum' started by Locqlynn, Jan 12, 2020.
  1. Locqlynn
    Locqlynn New Member
    chattanooga
    Ive read some conflicting info and im confused. My headlights are very dark so i figured i need new bulbs.
    Which bulbs on amazon are pretty good but will not break the bank. Thank you!
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Run your VIN at https://toyota.com/owners
    Once you know what type of headlights you have (HID or Halogen), report back here.
    donbright likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,336
    5,395
    Pacific Northwest, USA
    Headlight bulbs either work or they don't work or sometimes flicker as far as I know? Could it be that your headlight covers need cleaning?
    cyberpriusII likes this.
  4. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Odds are, you have halogen bulbs, but better to check than make a mistake. If you buy the halogen locally, should be $8-12, depending.
    Installing is a different problem I find it easier to partially remove the bumper and then remove the entire fixture, YMMV.
    BTW, last few days I have seen a number of Gen II running "one-Eyed."
    I suppose the bulb went out and they found out what mechanics are charging to replace them,:p
    Oh, Priuscamper is right...btw.
    I clean mine with
    kris
    George W, PriusCamper and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Did you exclaim "padiddle" :p.
    Or was it just you in the car:whistle:?
  6. Locqlynn
    Locqlynn New Member
    chattanooga
    Multi-Refectr Halogn Auto-Of Headlamps
    thank you for telling me about the website!
  7. cyberpriusII
    1,157
    1,850
    Hyampom
    Was that piddle. Haven't done that in a car since my accident a year and a month ago (actually didn't do it then, either). :D
    kris
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Since you have Halogens, there are plenty of affordable choices. Look for H4 or HB2 (9003) type bulbs. I wouldn't go much above 4300K (kelvin color index), but you might like brighter white (or purple) lights.
    Like @PriusCamper and @cyberpriusII kindly mentioned above, you can make a purchase at one of the local parts shops and possibly get 2x for under $15 total. Do check your headlight lenses for exterior cloudiness, as the UV coating wears on many housings, they might need polishing and then another UV clear coat protectant applied.
    Least expensive 4300k two (2) pack on fleabay from the US with decent reviews/free returns. You may get what you pay for.
    H4 9003/HB2 12V 60/55W Direct Replace Auto Factory Halogen Light Bulbs | eBay
    If you want to live on the edge, and for around the same expense, you could pick from a LED replacement below.
    h4 hb2 2007 Toyota Prius Base 1.5L | eBay
    Please report back with what you ended up purchasing and how they performed.
    Raytheeagle likes this.
  9. jessiejosco
    jessiejosco Member
    62
    42
    I just did the drivers side on our 2005. They don't leave you much room to change the bulb but I managed to do it by just removing the fuse box cover. The hardest part was figuring out that the rubber boot over the bulb had to be rotated to release it from the housing. They don't mention this in the owners manual and you can't get a good look at it in the car. The boot was also really stuck to the old bulb so I ended up releasing the bulb clip and taking them out together. I though it was going to be a problem slipping it over the new bulb in the cramped space but it slipped on easily. It must have been dirt on the old bulb.
    The passenger side you do have to remove the intake snorkel but it looks like you would have more room than on the drivers side after you do that.
