Need PCM Plug
Discussion in 'Gen 2 Prius Main Forum' started by VA-Scott, Jul 3, 2023.
  1. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    Attempting to install the EV switch in my daughter's '05, I broke the plug that goes into the PCM.
    Does anyone know where I can purchase one?
    Then, of course, I'll have to unplug all the wires and put them back in the right order.
    As it stands, there must be a short there because I get the "transmission P lock mechanism is abnormal..." error, and the car is dead-in-the-water.
    (Used PriusChat often for tips; first time posting a question)
  2. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    I have an extra car sitting here I don't know what the PCM abbreviation is I have a whole '05 sitting out here in mint condition that will never be on the road again well there's parts missing off it now but it was in great shape before I started taking the parts off of I don't know what an EV switch is for a generation too so good luck with that but I probably have the plug that you want and droves I am in Central North Carolina not far from Virginia depending upon where you are I'm in 27243
    52,822
    is there a salvage yard in the area?
  4. Tombukt2
    13,847
    2,515
    Durham NC
    What is the PCM plug? I don't know it by that name
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
  6. mr_guy_mann
    4,113
    2,011
    NJ-USA
    Find a wrecking yard - you need the plug from the same position on the PCM (just get all 4). Also can look at ebay for a complete engine harness.
    If you broke your connector, you'll want to practice removing the terminal locks and unpinning terminals before attempting this "for real".
    Unless your damaged connector won't go in at all, may want to scan all systems on the car and diagnose the park fault before messing with the harness.
    Here's a thread that reviews several scantool apps and devices.
    https://priuschat.com/index.php?posts/3290690
  7. Tombukt2
    13,847
    2,515
    Durham NC
    I have them hanging right here You can have them all before the car goes away
  8. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    Don't Prii ascend to the heavens like the divine works of eco-sainthood they are?
    Thanks; there's one about an hours drive away, so I might run out there Saturday.
    {Sorry for the delay; medical issues have kept me busy)
  9. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    I didn't know its name either, but it's the computer on the right of the three behind the glove box.
    (Sorry for the delay in response; medical issues have kept me busy)
  10. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    Thanks, Tom, but I'm in Northern Virginia (aka Occupied Virginia), and NC is quite a hike.
    I'd be glad to pay postage if you're willing to mail it to me, though.
  11. VA-Scott
    VA-Scott New Member
    Virginia
    SE
  12. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    Transmission P lock can be traced in the wiring diagram. It starts at a fuse under the hood, called p con. I'm not sure if you had this error prior but it's a somewhat common one. The fuse also supplies constant power to the gateway. If this fuse is blown, or wire open/short vehicle will likely not start depending on where the issue is.
    P con goes from the under hood fuse box to a passenger side junction down by the footwell. It continues on from there. I'd start checking p con for power beginning at the connector at the top of under hood fuse box after confirming fuse is good and it has power.
    #12 Goodcitizen, Jul 6, 2023
    VA-Scott and Tombukt2 like this.
  13. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    Sorry for the long delay. Thanks for the fuse info but, sadly, it's good.
    I got a plug from the Pick-a-Part junk yard for $6, and bought the pin removal kit for $16, but I still could not get most of the pins out.
    I ended up cutting the wires and soldering/shrink-wrapping each one.
    Might I have fried the PCM unit (also called the HV ECU) when I shorted the wires in the plug? There's a guy parting out his '07 who has one.
    #13 VA-Scott, Jul 29, 2023
  14. Tombukt2
    13,847
    2,515
    Durham NC
    There should be plenty of those around I got three or four here any of the battery rebuilders in any town will have this stuff cases and what not stacked up behind the shop ready to go to the dump The guy I went to see up in Virginia the hybrid doctor his little hole in the wall shop Man out near the side yard and the dumpster was so stacked full of metal cases I mean thousands of them It was like men take whatever you want they're more of a problem than a good thing when you get like that. So you should be able to find plenty of ECUs PCMs whatever the heck they are more power control module there you go yeah that's the one that's back in the battery case any battery rebuilder should have possibly hundreds of them laying around $5 whatever they're going to go in the trash.
  15. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    I'm not sure that is correct. The Hybrid Vehicle Control ECU is variously referred to as the HV Control ECU and also HV ECU in the repair manual.
    The Powertrain Control Module (PCM) is a separate ECU although it does talk to the HV Control ECU.
  16. VA-Scott
    VA-Scott New Member
    Virginia
    SE
    Thanks; I'm sure you are correct. I saw it called the PCM someplace.
  17. ChapmanF
    19,008
    I'm not sure Toyota's ever called anything in the car the "powertrain control module". I might have missed it.
    The one that conducts the orchestra, they've called different names. In Gen 1 it was the "HV ECU". In Gen 2, it was the "HV control ECU". In Gen 3 it became the "power management control ECU". I'm not sure what its later names are.
    There has been a "transmission control ECU" in Gen 2 and Gen 3 at least, and that's a highfalutin' name for the thing that moves one metal pawl in the transaxle in and out of Park.
    I will say, it helps a lot when posting questions to at least look up and learn the Toyota names for the things, as opposed to what they might have been called someplace, because that helps us all be on the same page.
    Toyota Service Information and Where To Find It | PriusChat
    The wiring diagrams (also found through that link) do show the part numbers of the different connector housings, and the way the terminals are locked in and released.
  18. dolj
    dolj Senior Member
    8,640
    4,391
    It looks like powertrain control module is an SAE term and is used throughout the repair manual in SAE defined codes. Toyota does not give its equivalent name.
    There is, though, a Power Source Control Module and it is this one that talks to the HV Control Module.
    Also littered copiously through manual are references to ECM/PCM and ECM (PCM), so I guess SAE's PCM is Toyota's ECM.
    #18 dolj, Jul 29, 2023
