Need pinout for engine control module 89661-47390
Discussion in 'Gen 3 Prius Technical Discussion' started by anonymous, Aug 5, 2020.
  1. anonymous
    anonymous Member
    177
    104
    US
    Does anyone have access to the pinout information for the gen 3 engine control unit (part # 89661-47390)? I want to find the two wires that go to the downstream oxygen sensor.
  2. anonymous
    anonymous Member
    177
    104
    US
    I found out myself the hard way and the blue (+) and white (-) wires of the downstream oxygen sensor correspond with these pins marked by the blue and white circles:
    Since I had to crawl underneath to find this out it defeated my need for this information; I tapped into the wires at the end on the sensor's side of the connector. But maybe this information may be helpful for someone else; if you have a P0420 and want to hack fix it but don't want to crawl underneath the car then you can tap into the wires right here.
    Cosmo Tigato likes this.
  3. Gse
    Gse Junior Member
    US
    I appreciate this post! How would I "tap" into these?
    Maybe this is where the cascade of engine codes started after my o2 was ripped off...
