Need plastic underbody panel clip
Discussion in 'Gen 3 Prius Main Forum' started by Johnspu, Feb 6, 2017.
  1. Johnspu
    Johnspu Junior Member
    Michigan
    I need a clip for the plastic panel underneath the car. It's directly under the passenger seat. It's not the push on type, it's female threaded on one end and large Phillips screw on the other. I've searched online and can only find the push on type. Do I need to go to a Toyota dealer? 2011 Prius. Thanks!
  2. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Toyota part = Toyota dealer. It is going to be really cheap and probably a common part.
    Simon
  3. Johnspu
    Michigan
    Ok,thanks.
  4. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
  5. Johnspu
    Michigan
    Unfortunately no. It has a threaded female end that screws on to a threaded stud under the car. I was hoping to avoid the long drive to the dealer. Thanks though!
  6. Mendel Leisk
    42,349
    Is it on the rocker panel, the big plastic piece running underneath the door sills, body colored? Those fasteners seem poorly designed, prone to fragment and fall off without any help from curbs. If so, my opinion: there no chance of that piece loosening, I would just ignore it.
  7. Johnspu
    Michigan
    It's holds the splash guard to the bottom of the car, this fastener is roughly under the passenger seat underneath the car. Wish I could figure out how to attach a pic.
  8. Mendel Leisk
    42,349
    Maybe you've just got to post a few more times, then you can post pics? You'll see a button below the editing window, saying "upload a file".
    Is it item 24 here?
    FLOOR & RAILS for 2011 Toyota Prius
    Seems like they're saying they'll sell you the whole panel, but not the fastener. That may not be the case though; I would check with dealership. They might be able to get it, for say $5~.
    Those are odd fasteners, seems like you can just push them on, but to remove you need to carefully unscrew, without pushing too hard, or it just pushes back on.
    Had a look:
    #8 Mendel Leisk, Feb 8, 2017
  9. Johnspu
    Michigan
    BINGO! That's it, thank you! I'll get to the dealer as soon as I can and see if they'll sell just the fastener. It broke off when my wife backed up over snow, now the panel hangs down a little and I don't want the whole thing to break off. Thanks
  10. Mendel Leisk
    42,349
    If it's the case that you do have to buy the whole panel, it looks like you could make something to replace just that fastener, say a wooden dowel for spacer and something wider as a cap.
  11. Johnspu
    Michigan
    Maybe a threaded bushing or something. I'll check with the dealer Friday and go from there. Thanks.
  12. Johnspu
    Michigan
    To anyone interested it's a $20 part, has to be ordered per Toyota dealer. I used a 1/4" threaded coupling, bolt/washer from Ace hardware, all's well for $1.30
  13. Mendel Leisk
    42,349
    Can you post a picture? That'd be great. And/or Ace Hardware link(s)?
    I noticed when I backed out the screw when taking my pic, I could subsequently just push it down, and it was click-click-click into place. Like it's just sort of friction gripping on that stud. Which I assume is welded to car body?
  14. Johnspu
    Michigan
    Sorry, I don't have a pic or link. I bought a 1/4" by 1" long threaded coupling, screwed that onto the threaded stud under the car, then fastened the splash panel with a 1/2" long Phillip head bolt with a lock washer. The guy at Ace knew where everything was, I'm sure other hardware stores would be just as helpful.
  15. ItZGr8t!
    ItZGr8t! Active Member
    75
    284
    IE
    Same thing happened to us last week! driving down the freeway then we heard this loud metal clunk sound underneath and sure enough something had actually pierced through that plastic shield which had ripped 3 of the white plastic fasteners holding it. Got home safely & took that shield off hopefully would be able to order it next week. But now the orange cables going to the front from the back battery are exposed, not good :mad:
    this part...
    Under Cover, LEFT for 2011 Toyota Prius|58166-47020 : Toyota Online Parts | toyotaonlineparts.com | Toyota Parts Online
  16. leese
    leese Junior Member
    When you call your local Toyota dealer it is part number 90467A0030C0 They are about $2.20 a piece. Priuschat won't let me post a link until I post 4 times sorry.
  17. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Using your part number, I Google searched. It appears to be available from Rock Auto for $1.88:
    http://www.rockauto.com/en/parts/toyota,90467A0030C0,clip,1001711
  18. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
  19. Mark Kopache
    Mark Kopache Junior Member
    Averill Park, NY
    As a side note, if you have a leak in the back brake lines, you'll need to removed these two under body panels to get at the left and right brake lines (as least for the Gen. 3s).
