Need Power / Ground Schematic for MFD
Discussion in 'Gen 2 Prius Main Forum' started by germanaudiotech, Oct 21, 2018.
  1. germanaudiotech
    germanaudiotech Junior Member
    Hopefully someone can help me figure out how to power on the heads-up display (multi function display - MFD). I have 2 white plugs, which wires are the Power and Ground? 2006 - 2009 Prius
    52,854
    welcome!
    if not, it should be available at tech info.toyota.com
  3. germanaudiotech
    If someone has this information it would be very helpful
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    If you’re in Los Angeles—or any other community where the local public library subscribes to the ChiltonLibrary service—you can get the pages from the Electrical Wiring Diagram books for model years 2012 and earlier for free. Start with this link: https://www.lapl.org/chilton
  5. germanaudiotech
    Dang, I haven't been to a public library since the 90s
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    3 connectors on back of mfd
    The one that has power has the 6 big pins across the top. That’s m13
    Has 26 pins. Pin 1 is on the left of the cable connector.
    Pin 1. Ground
    Pin 2. ACC
    3. B+1
    10. Ignition
    Let us know if it lights up. It won’t do anything without gateway ecu data
    Though.
    germanaudiotech likes this.
  7. germanaudiotech
    Thanks for the reply. I am trying to get it to show anything on the screen and test touch-commands. Even a Toyota startup logo if possible.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Well those are the power pins. I doubt it will do much without comm to the gateway.
    Ground pin 1 and apply 12 volts to pin 3 & 10.
  9. ChapmanF
    19,020
    My guess is it'll do pretty much everything it doesn't need gatewayed data to do. So the mileage barchart won't be very interesting. :)
    I've got a 7" Denso unit from a 2012 sitting on a shelf with battery and ground, and it will happily power up, play CDs/DVDs/MP3s, tell me I don't have any radio or XM stations, and show me on a map the last place it thought it was when a GPS antenna was connected....
    -Chap
  10. germanaudiotech
    Its not lighting up..
  11. germanaudiotech
    Nevermind, got it.
    Pin 14 is illumination
  12. kenneth winter
    kenneth winter Junior Member
    38
    tn
    Hey EdtheFox.
    I used this information from year ago to trouble shoot my MDF. I found I have no ground on the PIN 1. brown wire.. it actually has 8.3 volts.?? How do I track down the brown wire fault?
