Need quick help, rear license plate light replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Jul 21, 2019.
  1. kehyler
    kehyler Member
    84
    32
    blah
    Hi All,
    It looks like I need the rear license plate light replaced (its burned out), and I have a safety inspection within a week. I've got two questions:
    (1) Anyone know the part number for the bulb?
    (2) Anyone know a resource that explains the procedure for replacing it?
    Thanks!
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Your first stop is YouTube "prius license plate bulb"
    mikey_t, Montgomery and Merkey like this.
  3. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Bulb types are in the owner's manual
  4. Mendel Leisk
    42,250
    That said, if you just walk into a dealership parts department and ask for the bulb, they'll figure it out.
    Open the hatch and look on the inside, there's a couple of pop-out panels: bulbs screw in behind there. Owner's Manual has something too I think, but really you just need to follow your nose.
  5. RRxing
    2,562
    1,839
    NEPA
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. kehyler
    kehyler Member
    84
    32
    blah
    Thanks all, I ordered the parts off amazon and I'll try and report back afterwards.
  8. Mendel Leisk
    42,250
    One $1 bulb??
    They have a bin of those at any dealership, lol.
  9. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Super simple to do.
  10. Mendel Leisk
    42,250
    Yeah main thing is to avoid handling with bare hands, getting skin oil on it. To make sure give it a wipe with a cloth dampened with isopropyl alchohol, last thing before install. Though maybe this more important with headlight bulbs??
  11. CR94
    CR94 Senior Member
    2,816
    1,236
    Northwestern S.C.
    Yes, those are plain ole incandescents, not halogens.
  12. Mendel Leisk
    42,250
    So not that important, don't get that hot?
  13. CR94
    CR94 Senior Member
    2,816
    1,236
    Northwestern S.C.
    Back when most household 120-v light bulbs were regular incandescents, did you use gloves to replace every burnt-out bulb?
  14. Mendel Leisk
    42,250
  15. larryhut
    larryhut Junior Member
    Kent, WA
    If I can segue into the same subject, but a different year car. How do you change the license plate lights in a newer Prius Prime (2019). I have checked YouTube, the manual, googled it and can find nothing for the newer Prius. There are no cut-outs in the rear hatch like the older Priuses where you can access the bulb. Thank you in advance!
  16. Mendel Leisk
    42,250
    Owners manual?
  17. larryhut
    Kent, WA
    Nothing in manual
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Your 2019 Prime is not a gen 3, so it is possible you will get more informed discussion with n the gen 4 forum or the Prime forum.
