Need seat replacement advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 4restg, Jan 24, 2022.
  1. 4restg
    4restg Junior Member
    Vermont
    Hello all. I spilled kerosene on the front passenger seat of my 2013 Prius plug-in (won’t get into the really dumb back story)
    Anyway, I really need to swap out the seat so the car is usable. I have two questions:
    -If I can find a used seat correct for the model, is it just a simple swap job, or will putting in a new seat upset the car’s computer? (Side note, I already know I need to take care not to trigger the airbag system).
    -Is it possible to replace just the bottom seat cushion? This is where the spill happened.
    Thanks for helping with my dumb problem!
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You can replace just the bottom on the seat. Have you tried cleaning it?
    You can check junk yards for seat replacements.
  3. Mendel Leisk
    42,361
  4. ASRDogman
    8,067
    4,089
    Those are good.
    There is a product called "Totally Awsome" that REALLY works well. I use a 50/50 mix with water.
    You can get it at the "Dollar(.25) Store".
    You might have to remove the bottom portion to get to the padding/foam so you can soak it.
    But it would be a lot cheaper than buying another seat...
    Also, leaving banana peels overnight will help obsorb the odor.
  5. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Finding a compatible seat from a wrecker to swap out is easiest way... Main concern is side air bag in seat... Assuming they do that in Gen3 like they did in later year Gen2, that's the expensive/risky part. Hopefully someone who knows Gen3 better will show up to this thread and let you know which Prius are compatible with a swap... But I'd go with what @Mendel Leisk is saying... Or just take it to an auto detailer. Because there's nothing wrong with the seat other than needing cleaning. Of course if you spilled like a gallon of Kerosene, then maybe that's too much? How much did you spill?
  6. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    Your odor problem maybe coming from the 2 inches of foam/cushion material under and inside the seat cover of lower seat. Get a junk seat for $50 bucks, clean just your seat cover and swap in the cushion material from the junk seat. A better solution would be to find a matching seat with blown airbag and just swap in the entire lower section. Be safe and avoid the airbag in upper part of seat
