Need some help regarding front speaker component installation
Discussion in 'Gen 2 Prius Audio and Electronics' started by flareak, Sep 8, 2008.
  1. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    I have a 05 without nav and without the JBL system. But I was wondering how I would connect the crossover for the front doors.. i'm assuming there are different wires leading to the original speaker and the original tweeters, so I'm not sure which would i use for the crossover.. or.. should i not use the crossover at all?
    (before people tell me to go search other posts, i'll say i have tried searching and i have read sparky's guide)
  2. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    The wires leading to the tweeter are full range. Another pair jumps off from the tweter & goes down to the mid-bass driver in the bottom of the door.
    Use the wires that are input to the tweets as input for your aftermarket crossovers.
  3. flareak
    1,016
    St Louis, MO
    thank you thank you :)
