Need some help regarding this issue.
Discussion in 'Gen 3 Prius Technical Discussion' started by JLJK, May 18, 2021.
  1. JLJK
    JLJK New Member
    Malaysia
    Good Day guys,
    I wanted to ask do you guys counter this issue during cold start or low speed? May I know what's the issue about this ? Any solution? Or the only options is to overhaul my engine? Because it started to consume lubricant oils. Thanks for your reply.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,065
    6,934
    Texas Hill Country
    If it goes away after a minute or so and drives ok, its a blown head gasket. If it continues it might be a plug, coil or injector. Excessive oil burner and hg? Replace engine.
    If hg:
  3. JLJK
    JLJK New Member
    Malaysia
    It wasn't vibrate like this, only some minor knocking sound and vibrating
  4. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Is t
    Is the cooling system low at all?
  5. rjparker
    11,065
    6,934
    Texas Hill Country
    Is it constantly happening or does it go away after a minute or two and then drive ok?
    Answering questions will get you results.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :whistle:
    Tim Jones likes this.
  7. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I have to read this every month or so and I still cut up a bit.......
    "Someone was ahead of me driving slower than the posted speed limit. Told my wife that according to the Prius group I can flip this person off for delaying us a minute or two. She was like wow that's crazy...Did it maintaining the posted speed limit and it felt great!" - PriusMPGenius
    "Also, are there really high mileage cars in Europe?" - Bill Norton
    "My rear lights beeped and flashed once, saw sparks and smoke." - pstuebs03
    "Does anyone know of an CARB certified oil catch can?" - kehyler
    "$7,500 is pretty much close to paying off so." - neel
    "Just because I don't check my dipstick doesn't mean car has been neglected...But I will be trading it soon because I want something a little more fun." - BrianPB
    I'm sorry but If I go to a dealership and get oil changes every 4000 miles, then I shouldn't have to check to see if I am completely out of oil in less than 4000 miles." - Tedh1979
  8. Mendel Leisk
    42,315
    @JLJK : how many miles on it?
  9. JLJK
    JLJK New Member
    Malaysia
    Hi guys, sorry for the late reply. reaching 180,000 km soon. Driving is fine just cold start will have some minor vibration and sound .
  10. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    What about the antifreeze level?
    Usually when the head gasket goes out the water is low.
  11. JLJK
    JLJK New Member
    Malaysia
    Nope, the cooling system is good. Water level is at full.
  12. Mendel Leisk
    42,315
    Look into Exhaust Gas Recirculation cleaning, it’s due. Might be overdue, a leak down test can assess head gasket integrity.
    Anyway, more info:
    Bad Flywheel | PriusChat
