Need some help replacing the 12v battery, any info would be appreciated!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Sid Frey, Dec 26, 2018.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    This YouTube might help you?
  2. Mendel Leisk
    41,496
    Look into electronic load testers, like the Solar BA5.
    padroo likes this.
  3. alanclarkeau
    7,045
    7,592
    Just bear in mind that thee task of a PRIUS battery is quite different from the old cars he's talking about.
  4. Mendel Leisk
    41,496
    Still, a battery in good shape will display CCA above spec, and one that's failing will show lower than spec. Regardless of the demands, testing the battery in similar manner is still valid I think.
    Have we had this conversation before; I'm getting a serious deja vu, lol.
  5. padroo
    padroo Senior Member
    2,763
    2,252
    #25 padroo, Mar 28, 2019
  6. alanclarkeau
    7,045
    7,592
    I'd still suggest that the OP have a look at the YouTube I posted - Cold Cranking Amps is irrelevant to a PRIUS, though the battery still has to be sound.
    mark27lim likes this.
  7. padroo
    2,763
    2,252
    If the battery is sound it should be able to produce most of it's cold cranking amps and if it can't it will gradually decline with time and eventually fail. I understand the Prius does not need all the CCA, kind of like running a tire low on air, if it gets too low it will fail.
    It got to -20 F. here this winter and a battery that will start a car in warm weather may not start a car in cold weather and northerners are well aware of this fact. Batteries are more dependable than they use to be but old timers here take their car to the shop in the winter and have the battery tested, antifreeze checked and snow tires put on the car.
    Even a new battery CCA will drop in the winter and a weak battery will fail.
  8. Mendel Leisk
    41,496
    I think there's some conflation in your argument Alan: to say low CCA is not a problem in a Prius battery, since it's not cranking. The thing is: a battery in good health will have CCA well above spec, and one that's one that's degrading will display CCA below spec, sometimes significantly.
    robsnyder20, mark27lim and padroo like this.
  9. Jess Parthew
    Jess Parthew Junior Member
    Vancouver BC
    E2AA1C6E-0C2C-4D43-A2DF-CFA871FA6D83.jpeg If you are still looking for a replacement battery a Walmart Everstart 121r, fits like a glove.
    krmcg and robsnyder20 like this.
  10. padroo
    2,763
    2,252
    What is all that extra equipment attached to the battery?
    krmcg likes this.
  11. Jess Parthew
    Vancouver BC
    That's a fuse block, one each for the two way radio, meter, top light and data terminal.
  12. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Seems like the dealer are really pressing for battery replacements. I got a tester for mine just after the 36k warranty was up and the old battery checked out at just above 200 CCA. A year and a half later, the advisor said you gotta get that battery replaced, brought it home and guess what, still tested at just above 200 CCA. The rating for our battery is only 290 CCA. Did anyone get a new OEM toyota true start battery and what are they rated at? I know CCA doesn't matter but I find that having a battery that says it gives 550 CCA and drops to 350 CCA better than one that starts out at a measly 290 CCA. Heck, just detailing the car for an hour will make my radar detector detect a low battery condition, even though the car still starts fine.
  13. Mendel Leisk
    41,496
    Is 290 CCA stamped on the case? I'd guess it's more like 325 CCA, rated. A new battery in good health rated at 325 CCA will typically test higher than that rating, say 375~400.
    200 CCA does sound really low. What's the voltage, if you check it first thing in the morning?
  14. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    CCA never mattered in a Prius. Its the amount of voltage that its got.
    Fully charged: 12.5+ volts
    Half charged: 11.0-12.4
    Discharged: 10.9 and lower
    alanclarkeau likes this.
  15. Mendel Leisk
    41,496
    Yeah the battery doesn't crank the engine, but CCA is still a good indicator of battery health.
    #35 Mendel Leisk, Sep 18, 2019
  16. Mendel Leisk
    41,496
    You were very close:
    Still, any battery that reads significantly lower than spec'd CCA is not going to last much longer.
