Need some help.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jun 14, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    1. I replaced a wheel bearing but the dust deflector is missing, how critical is this?
    2. Does anyone have a spare steering knuckle for the driver's side on a Gen2?
    3. Is there an aftermarket source for the weather stripping that goes on the hatch? Not the part that lifts up, but the big one you see when opening the hatch. A new one is over $200 from Toyota.
  2. Tombukt2
    Tombukt2 Senior Member
    13,700
    2,480
    Durham NC
    Not critical at all knuckle hub say is 67 bux from Detroit axle on Amazon trunk weather stripping I usually have several laying around and you can just pull them off any car at LKQ or a towing lot probably $20 or something many of them will be like new
  3. Prius92
    595
    122
    Iowa
    The hub is like $170 on Amazon, the DA one is the steel one for the Prius C/V/Yaris and won't work. DA doesn't make one for my car.
  4. Tombukt2
    13,700
    2,480
    Durham NC
    You are talking the big aluminum silver thing that houses the wheel bearing the outer tie rod stood on so you can steer . I just looked them up the other day. I have some here off they no go bad . Even if you damage hole the bearing is bolted in .
