Need to change key battery, will a 2032 work the same as 1632?
Discussion in 'Gen 3 Prius Main Forum' started by Freeze Time, Feb 26, 2019.
  1. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    This will be the first time I change the battery in the keyless entry fob. I can get a better deal on the 2032 battery but the battery in my key fob is a 1632. Are they the same or will only the 1632 one work?
    I think I found the answer. The 2032 is a little bigger so it won't fit. Oh well.
    #1 Freeze Time, Feb 26, 2019
  2. JC91006
    16,674
    8,519
    You can get these batteries anywhere....even jewelers that replace watch batteries will stock them.
  3. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    LOL... "a better deal"??? Those batteries cost only a couple dollars a piece at most. You buy it in multiples, it is about $1 each or less. How much saving were you expecting?:LOL:
    will the engineer likes this.
  4. JC91006
    16,674
    8,519
    I buy 3 of the 2032 at the 99cents store for 99 cents
  5. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    I saw one for 4.35 and a 5 pack for 3.99 at Walmart. I will check out the 99 cent store for the 1632 ones. I have a 2015 Prius and the battery is a 1632 so I just assume I can only use 1632.
  6. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    My MDF have been bugging me low fob battery for 4 months, still ain’t gonna change it. Your not the boss of me.
    Landon51 likes this.
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  8. Salamander_King
    11,009
    8,935
    New England
    Yap, 1632 and 2032 are different size 16x3.2mm vs. 20x3.2mm. They are not interchangeable. I looked it up, there are some 1632 replacement batteries though. CR1632 are Replacement for: RN-CR1632, BR1632, KL1632, DL21632, ECR1632, 1632, L1632, NSN - 6135-01-452-8160:
  9. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    I also ignored it for months but now it's gotten to the point where I need to use my key to open the door. I found that opening the key fob makes it work a little better and it mostly recognizes the battery but it's much easier to just get a replacement. Thanks for your posts.
    Robert Holt likes this.
  10. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    You're overthinking this. Just buy 1 and be done. Buying more to save a few bucks isn't worth the added clutter. You'll probably end up misplacing the extras anyway by the time you need them again. Or at least I would...
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    The 1632 is available on Amazon although you must be careful to avoid Chinese fakes. I’ve replaced each our key fob batteries twice in 6 years, or about every 2 years. The “Use By” date is 2024, so I think if did make sense to puchase the package.
    Bay Stater and Raytheeagle like this.
  12. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Unless you are organized and have a box or drawer where you put all your extra batteries and label them with what they are for. Like in the above picture posted while I was typing
    Mike
    Bay Stater and Robert Holt like this.
  13. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    They are fake in name only. They are all made in China or somewhere in the Far East and labeled with brand names only to sell for a higher price.
  14. Robert Holt
    1,313
    888
    @Georgina Rudkus , I cannot agree as the quality control for the lowest-priced Chinese manufacturers seems particularly poor, whereas electronics that are made in Japan or Taiwan seem to be much better on the whole. Battery packs for electric bicycles that have Chinese lithium-ion cells are about 40% cheaper than the exact same vendor’s proffered versions that are said to have Sanyo li-ion cells made in Japan. Purchasing batches of LED flashlights from China I had a 20% or 1 out of 5 failure rate, whereas versions from Japan or Taiwan, while noticeably more expensive, had 0 failures. Back to point: when searching for the 1632 replacement batteries, I carefully read all the reviews to screen out what appeared to be the cheap Chinese knockoffs versus what were apparently ones made in Japan—one clue is the quality of the packing material, another was the presence or absence of a “use by” date, and the final one was the proportion of the batteries purchased that were “Dead On Arrival”.
  15. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    I've bought CR2032 coin cells from China for over 10 years. Every one that I've got has been good. That's not to say that other products have the same reliability record.
  16. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  17. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  18. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  19. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  20. Salamander_King
    11,009
    8,935
    New England
    Do I hear echoes? LOL:ROFLMAO:
    Raytheeagle likes this.
