Need to replace tires at only 17,000 miles !!!! HELP!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by docproteus, Sep 2, 2004.
  1. Bill60546
    Bill60546 Member
    388
    Chicago
    tires
    Would recommend consideration of Toyo tires. Have had very good luck with them after replacing Michelins (sp) on my various Hondas.
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Yes, I still run the tires at 44/42.
    Running at max is no big deal, especially with well built tires like that. Strangely enough, I got data from someone strongly against hybrids that going beyond that is possible (though stupid). By doing that and driving nothing but long cruises on the highway, he was able to inflate his non-hybrid data to make Prius look bad. Only, he wouldn't tell the naive that he was doing that.
    Sorry, I can't help you with the trade-in decision. But by the time others are ready for regular replacement or those buying a 2006 Prius, I'll have enough data gathered to make the choice a no-brainer.
    As for crosswinds, I have virtually no little data to draw a proper conclusion. The seasons haven't been right to be exposed to enough really windy days where I'm actually cruising on the highway at that time. I kind of lack a frame-of-reference too. The only other vehicle I ever drive is a full-size conversion van. Obviously, Prius totally blows that away.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i find it hard to believe that any car on the road today cannot be "4 wheel aligned"
    and John, sorry i guess the 4 wheel alignment was done on your other car. i just noticed that is was under the classic maintenance page.
    with computer alignment systems it isnt necessary to hook up the back wheels. ive seen my brother do this a million times. (he had problems for nearly a year finding a reliable alignment guy for his shop (he was the manager of Les Schwabs in Bremerton, WA) so he was the alignment guy most of the times during that period.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Per repair manual - anything that's out of spec on the rear requires replacing the suspension components. However, as Frank mentioned, any tech who wants to save the customer some time and cash could try to bend things back into place.
    I suppose in my case I "know" I haven't hit anything harsh on the rear, but I did roll into a parking curb w/ my right front at a few mph by accident last week. Since my steering wheel is very slightly cocked to the right, steering is a bit dartier on the freeway, and general tire noise has increased somewhat. Based on that, simply having a front thrust adjustment could suffice unless caster was affected as well. Or, if things are still at dead 0 degrees, I could be imagining it all. :roll: :lol:
    Either way - It's unfortunate that most shops will charge the extra $20-$40 for a "4 wheel" when in my case I'm fairly certain the rear isn't out of spec, and there's not a whole lot they could do if it was.
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok im guess my explanation is vague. in a 4 wheel alignment, it is not necessary to have all wheels be adjustable.
  6. HTMLSpinnr
    5,341
    920
    251
    I suppose I wouldn't call it a 4 wheel alignment unless all 4 were being adjusted. Unless... the fronts were being adjusted relative to the rear.
    From what I've read, a basic 4 wheel references front to rear. A full 4 wheel includes adjusting the rear. Unless they're doing a full 4 wheel, I feel they should only be charging for a front wheel adjustment, even if they're doing it relative to the rear.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    as i understand it and as someone has mentioned in this thread, on nearly every car, the rear wheels are not adjustable.
  8. FredWB
    FredWB New Member
    331
    San Diego, Colli-fornya
    I finally ended up with same tires and size that John is using. I tried the 195H60X15 Hydroedge for about 1400 miles (30 day agreement with Evans Tire) and decided to put the stock size back on. Now that I've driven both this is what I think the trade off is with them. The 195H60X15 was more stable and solved some of my wandering problems. Cross-winds had less effect. Most of my mileage with the larger size was on the freeway as I drove to Vegas and back. I averaged 49.6 mpg (after correction for slightly smaller diameter) while my overall for 8500 miles is 48.6 mpg and rising. I'm used to seeing 50-55 mpg on the freeway at 65 mph depending on wind, temp, etc. I felt the larger size tire didn't allow me to build the displayed mpg on those downhill sections or around town like the std tires did. So the trade off at least with the larger size is somewhat increased stability for some mpg (maybe 4-5???).
    Oh and I don't know about John, but the hydroedge tires seem a bit stiffer than the stock tires so at 42/40, which is what I'm running now, I've developed at least one more rattle I didn't have. And the sqeaky center part of dash sqeaks more too. The rattle is the small panel on the drivers side below that small window on the dashboard. I just stuck a few small pieces of felt in just to see if that was it and it did silence it. The squeak is somewhere inside the dash below the speaker grill and seems temperature dependent too.
    But I think the hydroedge tires are a pretty darn good replacement for the stock tires.
    Fred
  9. marshk
    marshk New Member
    New York
    I brought my '04 Prius in for its 15,000 mile inspection and the dealer said all 4 tires needed replacement.
    Lucky for me the dealer came right out and offered to replace them free of charge before I even started to complain. I think Toyota realizes the original tires are fairly poor.
    Replacement tires are Michelin Harmony's.
  10. removeum
    removeum Member
    407
    El Paso, TX
    Did they say why you needed new tires? Is it due to the car not being properly aliened? I currently have 15,084 on my 04 Prius and have had the tires rotated every 3,000 to 4,000 miles without a hitch.
    Ben
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well i guess i will have to let ya know in about a year or so, but at nearly 6000 miles, my tires still look practically new.
    i did do a rotation at 5000 miles since the front tires will wear quicker.
  12. marshk
    marshk New Member
    New York
    <div class='quotetop'>QUOTE(removeum\";p=\"44867)</div>
    They just noted that all the tires had been worn down. I had to agree, the tread was way down on all the tires and they had been wearing more or less evenly. I did have rotations done at 5,000 and 10,000 miles.
  13. jchu
    jchu New Member
    1,063
    Nampa, ID
    At just over 15,000 miles still have about 6mm of tread all the way around on '04 OEM Goodyear Integras.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    6mm @ 15,000 is normal. i have 9 mm @ 5,000
    i do my own rotations and then take my vehicles in for rebalance and rotate every 15,000 miles.
