Need wiring diogram for prius c, Please help!!!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sergkuk, Jun 27, 2014.
  1. Sergkuk
    Sergkuk Junior Member
    sac
    I bay car after accident. I fix body, but can't ran car. I have 3 errors. Two errors with flow sensor, and one with inverter bus communication(U0100). I try change flow sensor, and inverter, not help. After clear faults car run and working about 5 seconds, and faults come again. Maybe lost same ground. I can't found wiring diagram.
    Please help.
    #1 Sergkuk, Jun 27, 2014
  2. otbiker
    otbiker New Member
    25
    The CANBUS error is what is shutting you down. You'll need to find a shop with access to All Data for the wiring diagram, or a dealer.
    Good Luck
  3. Sergkuk
    sac
    Two masters try fix my car, but can't found any real problems.
    Thanks' for support.
  4. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    Wiring diagrams can be found in the Toyota TIS website. You can subscribe for two days rather inexpensively. https://techinfo.toyota.com.
    RM-927_nam_vzw_100 ?
  5. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    Or Alldatadiy.com
