Needed: OEM cat c theft deterrent solution; already had 1 stolen
Discussion in 'Prime Main Forum (2017-2022)' started by peripatetic pri, Apr 12, 2021.
  1. slowmachine
    slowmachine Member
    69
    70
    Alton, NH
    The dealer installed the Miller Cat shield on my 2021 Prime.
  2. MBurch
    MBurch Member
    30
    30
    Snohomish, WA
    2022 Prius Prime
    I put a Miller Cat on my 22 prime, took about 30-45 minutes - nice unit, quick delivery, had them throw in extra security bolts which they did - no problem with heat and it's been on for a couple of months now - no rattles either if you put the foam on right
    MILLERCAT 2016-2022 Prius Gen 4 Cat Shield™
  3. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    Get a tremor switch added to your car alarm or install a cheap secondary system. The combination of car alarming and a cheap CAT shield should deter someone from going after your CAT. The alarm will sound as soon as they lift the car - when they see the CAT shield; they'll most likely drop the car and run. Look for an easier target.
  4. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    The https://catclamp.com/media/ Cat Clamp looks like a good option. A sawzall won't cut through loose stainless cables like it can cut through an exhaust pipe or a thin sheet metal guard. To cut the cables a thief would need to have stolen a cut-off disc and a cordless angle grinder--possible but not common. No guard is perfect--you just need something to make stealing your catcon more trouble than the next car.
  5. chickenhawk
    chickenhawk Member
    261
    96
    CA
