needed on youtube: gen2 rightside [passenger side] control arm replacement video.
Discussion in 'Gen 2 Prius Main Forum' started by prius_deep, Jun 12, 2018.
  1. prius_deep
    prius_deep Member
    105
    38
    road
    what is needed on youtube is a good gen 2 passenger side control arm replacement video.
    geeman geeman has one for gen3 [bolt hits oil filter]. Gen 2 bolt hits ICE oil pan; engine needs to be lifted 3 to 4 inches.
    autodoc chickened out, at the start of autodoc video the part shown is for rightside, but they did the left [driver] side.
    and...
    Is that item pictured in the engine compartment with the glass peek hole part of AC? If you loosen the gray plastic top have you let your AC escape?! I heard air escaping. Do I now need to have my AC recharged?. It was fine before I became curious.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Funny, I was just thinking about this because just this weekend I replaced both lower control arms (along with inner and outer tie rods, sway bar links and sway bar bushings. Total costs for both sides plus rear brake pads=$140 from Amazon!) on my newly acquired 2008 suzuki sx4 and they were fairly easy and straight forward. Raising the motor? Man, this sound like a real beeotch. BTW, where do you live? That's a lot of corrosion compared to my vehicles.
    edthefox5 likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Wow that rust. If its that bad up top the suspension has to be destroyed underneath. Wish I knew where road was.
