Needing help prioritizing services-repairs /dealership quote
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dropofthesea, Sep 20, 2023.
  1. dropofthesea
    dropofthesea New Member
    Tulsa
    Good evening. I have a 2012 Prius V with 61600 miles that I had serviced at Toyota dealership and needing help selecting and prioritizing repairs and services. Any feedback and or advice is much appreciated. Thank you!
    Service Name Price
    [Primary]: MPI - MULTI-POINT INSPECTION MULTI-POINT INSPECTION MPI
    Axle Replace - Front: Driver side axle leaking axle grease.
    $970.72
    Sway Bar End Links - Front: boots are dry rotted. Driver side sway bar end links are torn.
    $546.14
    [Other]: Timing chain tensioner leaking oil.
    $257.72
    Throttle Body Service: Recommended by mileage 30K
    $49.95
    Mass Air Flow Service: Recommended by mileage 30K
    $49.95
    Cooling System Service: Recommended by mileage 50K
    $179.95
    COOLING SYSTEM SERVICE: Recommended by mileage 50K
    $149.95
    [Other]: trans drain and fill.
    $165.90
    Port + Direct Fuel Injection Service and Throttle Body Service: Recommended by mileage 40K
    $269.95
    Printed on September 11, 2023
    Quote expires on October 11, 2023
    Signature Date
    Multi-Point Inspection
    Subtotal $3444.10 Shop Charges $49.95 Tax $146.66 Total $3640.71
    #1 dropofthesea, Sep 20, 2023
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,889
    6,834
    Texas Hill Country
    Axle (will strand you), coolant (might save your head gasket), maybe sway bar bushings. Use Toyota parts, maybe not labor.
    100k miles transaxle fluid.
    Boat payment items:
    Timing chain and tensioner leaks , not until head gasket required.
    Fuel system and sensors clean. No.
    Independent shop with references for all this. Save money and better advice. Ideal if they know hybrids for future high dollar work but not essential for these mostly boat payment items.
    By the way, an independent might offer to replace the axle boot and not the whole axle although that is more labor and depends how bad the leak is and how long it was leaking. If axle is replaced use oem.
    #2 rjparker, Sep 21, 2023
    52,697
    any symptoms?
  4. dropofthesea
    Tulsa
    Thank you so much!
  5. John March
    John March Junior Member
    32
    Winston Salem NC
    2014 Prius v wagon
    I'm going to assume DIY is out and everything must be performed by a shop.
    I would goto a reputable local shop and get a price. My priority would be the Axle and Sway Bar End links as priority #1. I would also want the shop to check if this repair is actually needed / completely repairs the issues / check the suspension.
    I would not do the Throttle body service, mass air flow service, or fuel injection service based on my experience as these had little to no build up at triple your mileage.
    #2 Coolant is a drain and fill with a handy wing nut at the front of the engine to drain it so i'd ask my local shop how much a drain and fill is (reminding them of how easy it is to drain and fill). Would take about the same time as the oil. Toyota Parts department sells the coolant that is recommended so i'd bring the shop the coolant.
    #3 Trans Fluid - Buy this at Toyota and have local shop complete the service. Mine wanted $89 labor even though its about the same difficulty as an oil change.
    Keep and mind #2 and #3 I recommend drain and fill - I don't recommend any "flush" options.
    Timing chain tensioner i cannot give a recommendation on as I've not worked on it.
    If DIY - #2, #3 are easy afternoon projects.
  6. dropofthesea
    Tulsa
    Thank you. My steering wheel pulls to the right after even after they rebalanced tires. And there is fluid dripping in small amounts after I turn my car off, assuming this is the condensation from AC?….
  7. dropofthesea
    Tulsa
    Thank you. I appreciate you taking the time and providing your advice. Yeah DIY is a little intimidating for me but I’m open to learning. I was reading that Toyota axle rarely wear down so I wasn’t sure if I should have repaired or replaced…..
  8. bisco
    52,697
    clear fluid would be condensation
    i would get a second opinion at an alignment shop
