Net effects of green energy and old coal on new electrical demand
Discussion in 'Environmental Discussion' started by austingreen, Mar 30, 2015.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I would say yes. As long as renewable energy is used by someone, you have lowered the GHGs emitted by the full amount you generated.
    I don't care if I lowered my own, or if because of my solar panels, my neighbor's power guzzling plasma TV emitted less GHG.
    Trollbait and Jeff N like this.
  2. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    The choice program in ERCOT and the one in Palo Alto, CA include reliability. Their are grid and maintenance charges on my bill.
    I do pay less because of the federal wind subsidy. The choice system in texas, and other programs in Kansas and Iowa that are building so much wind mean that the federal subsidy is no longer required. Still solar still needs help, and if you are going to remove the wind subsidy, adding a coal tax is necessary to adjust for different pollution levels ($50/ton has been sugessted)Texas is fairly lucky because the main grid is contained only in one state, and the state can and has approved grid upgrades for reliability. The western and especially eastern grid need a great deal of federal help to get upgraded for renewables. The question isn't if these programs work, but if the price is right, are the subsidies right, and are they run properly to build the right amount of renewables and fossil back up plants, and if the renewables built cause the customer to have 0 or negative fossile fuel burned for their net use.
    I have seen no, zero utility back lash against choice programs. They actually when done properly should make the grid more reliable. We do see some utilities playing politics, as the energy provider of the choice programs is often a different company or group of companies and individuals. That means big utilities like Duke or Southern California Edison have lower profits. My goal does not include protecting big utilities profits.
    Then there is net metered solar. Some plans charge for grid reliability, some don't. in the austin system, the federal, state, and local utility subsidize the solar. The solar provider (home owner with solar on roof) gets the cash to make the system low cost, but gets assigned average grid emissions, and the utility takes the solar credits. All the utility customers pay a little to subsidize this even the choice customers. There is so little solar built though (3% mandated) that it doesn't cost the average customer much per year.
    In Hill's case though, I think he only got the federal subsidy. His utility charges him for the hook up and reliability, even though his solar probably makes his utility more reliable. They pay him less than market rates for the peak power he provides to the grid The utilities botched maintenance on the san onofre nuclear plant is what hurts reliability in southern california, not solar. In most cases the complaints are about lower profits and the ability to charge for incompetence. The California Public utility commission is also partially responsible for black our risk, as there process under builds cycling power (ccgt) and encourages power imports from out of state. In hill's case he can claim some reduction in ghg, but it may be more or less than his full electrical footprint.
    #62 austingreen, May 6, 2015
  3. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    At least for my Utility which will be introducing a renewable plan this fall (finally!), the renewable energy is separately accounted for. They purchase a certain amount in order to meet their legally mandated renewable targets. They separately purchase and account for a certain amount of renewable power through long-term production contracts to fulfill the use of their optional 100% renewable green energy customers.
    When excess renewables for the green energy customers spills over into the grid, that amount is not included in the overall renewable grid target calculation but it is certainly used by grid customers.
    There is almost never going to be an exact match between generation and demand, even for conventional grid power. It's all approximate and with hundreds or thousands of generators and millions of customer using power there is room for some small percentage of sloppiness in the system which results in slightly off-target grid voltage or temporarily off-target line frequency.
    There is no significant excess power put on the grid which does not get immediately used (ignoring deliberately saved energy through utility batteries or reverse hydro pumping). Some people pretend there is excess coal generation at night that EV owners can magically utilize without really contributing to CO2 emissions. Not true.
    #63 Jeff N, May 6, 2015
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Yes, but my point was that the additional payment for clean energy did not result in more clean energy on the grid.
  5. austingreen
    13,675
    4,213
    Austin, TX, USA
    Let's talk about a good choice program.
    1) 0 or negative net fossil burn, by overbuilding the renewable resource.
    2) Back up capacity already existing or built with the renewable
    3) Grid built out to reliably supply both the renewable and non-renewable electricity
    Let's say customer A purchase power through a choice program that aggregates other choice programs, and builds both wind farms and grid connections to the farms. The utility coordinates the program with the grid operator to make sure there is enough reliability, an the grid and cycling resources (ocgt and ccgt). Because of all the customers type A, wind is built in different areas so that peak wind and troughs are different, so total grid impact is more stable than a single wind farm. Let's say in a year A actually gets electricity from 10,000 kwh of natural gas being burned, but other customers because of the turbines burned 8000 kwh less natural gas and 3000 kwh less of coal.
    Do we charge customer A with their gross use of 10,000 kwh of natural gas? Or do we throw up our hands and say A used grid average. Or do we look at net effect of +2000 kwh of natural gas and -3000 kwh of coal and say its about 0?
    My call is to say its about 0. Now there is a federal subsidy, and some programs don't build enough renewables, or subsidize on top of that. Lets think about a good program that strives for less than 0 net fossil fuel and is subsidized. Why look at gross instead of net? These subsidized choice programs often have lower cost to tax payers and utility customers than other methods to build renewables.
    Now lets look at customer B. B owns a house or building and has plenty of cash or credit to get loans to build a off grid system. They install a big enough battery to provide full power when the sun isn't shining. They buy a diesel generator to back this up, incase they misjudged. Then they build enough solar to provide enough power with the battery for the worst month of the year. In some remote locations this may make sense. If they plan right and never use that diesel generator, I think we can all agree they don't use fossil fuel. But in terms of net fossil fuel use they do no better than A. There are subsidies for the battery and panels, and B, and if both A and B take the subsidies B is subsidized more. A also probably help pay for the poor to get electricity and grid reliability through their utility bill, while B does not contribute.
    I would think if you actually want to build renewables, and make it affordable to most of the population A is a better program than B.
    There is of course option C. C, puts up solar and a battery like B, but is net metered. C joins the grid and has a much smaller battery. Let's say customer C puts up panels for 125% of average power usage, and has a battery that holds about 30 minutes of power to peak shave and help with blackouts. C is going to consume fossil power when the sun doesn't shine, but offset more when it does. So C will have a gross fossil fuel use like A, but its net use will be negative. With proper regulation and pricing, C's installation will not only cost less than B's but the net fossil fuel impact is lower than Bs. Now C is the most complicated regulation wise, and the grid operator and utility commision must plan harder for these customers but that is not that complicated. My local utility also encourages C without batteries, but is experimenting with some batteries. These customers for lower lost sell their rights to claim the solar to the utility. This is less expensive than the utility building their own solar, which is mandated by my city.
    #65 austingreen, May 6, 2015
    Jeff N and Trollbait like this.
  6. Trollbait
    12,543
    EV's charged at night don't magically not contribute to CO2 emissions from a coal plant, I agree. A steam power plant does run inefficiently at night under low load.
    A steam locomotive is actually more powerful than a diesel-electric. One of the reasons we no longer use them, or steam powered cars, is because of the time it takes to boil all that water and get a minimum required pressure. Same applies to these power plants. On top of that, letting the boilers and piping cool and then reheating them increase the chances of something breaking. It's the expansion and contraction cycle that rips up pavement in winter. A plant might make steam, but not spin the turbines, in order to avoid that.
    So shifting electric use to night will let the plants put the minimum steam they produce to use making power, and might get them to a load that is more efficient. Which means less CO2 emitted per kW produced. Whether that results in lower GHG emissions over all depends on wht that shifted electric use would have been using during the day.
    Zythryn likes this.
  7. austingreen
    13,675
    4,213
    Austin, TX, USA
    I know you probably just ean not timed to use not excess.
    We can talk net or gross. there is rarely if ever excess solar on the grid, as solar at least in the US is smaller than demand - fixed plants (coal, nuclear, and steam natural gas that are on) + solar. Occasionally wind exceeds this level, and in most places those coal plants need to pay some charge to keep the wind off the grid. Sometimes in germany solar is excess.and is wasted. Often it is better to waste a little power than to underbuild or build storage. California underproduces so much that other states need to adjust their power to make supply work.
    solar or wind producing more at time than their owners is by design not excess. The idea is to provide enough power on average including grid losses, not to take renewable customers off grid.
    The grid operator has to match supply and demand. Its not very sloppy. They curtail wind or lower power at steam resources or add loads or spin up cycling resources (ocgt or ccgt natural gas are the main ones). Peak demand often uses the most inefficient resources, while night demand can either use the most efficient or the least expensive resources or a combination of both. More off peak demand makes it less expensive to build more efficient power generation (ccgt and wind).
    I'm not sure where that came from, but it sounds like a straw man. The argument is that if plug-ins are charged at night there is plenty of power generation capacity, only grid upgrades are needed. Of course if you don't build anymore plants, you will use more fuel (mainly natural gas, but also nuclear and coal) in the existing plants.
    If you do build more power generation for the cars, it is more cost effective than if you did not have the night demand. Say you build 500 MW of fast cycling ccgt natural gas (70% utilization), 500 MW of solar (25% utilization), 500 MW of wind (35% utilization) and eliminate 600 MW (90% utilization) of coal or natural gas thermal. I've only added 90 MW average power for the cars, and it cost a lot of initial capital, but look what happens at peak and in fuel usage. Peak power will jump from 600 MW to about 1150 MW (considering erocts peak factors for solar and wind). If the fast cycling ccgt is 58% efficient, and the steam plant was 38% eficient (typical figures) nartural gas use would go from 600 x 90%/38% = 1421 MW of natural gas to 500 x700%/58% = 603 MW. Grid reliability increased and only 43% of net fossil fuel burned. That solar chunk is the tough one, its easy to build the ccgt and wind, it just takes money. Now the cars would probably charge off of some of the legacy power, but it would be the stuff running anyway, and the cycling ccft could turn off if not needed and turn back on fast. If those plug-in buyers purchased that 500 MW of solar, the wind and natural gas could be built for the fuel and maintenance savings. .
    #67 austingreen, May 6, 2015
  8. 3PriusMike
    3,100
    2,419
    Silicon Valley
    And you have every right to say that.
    I just disagree.
    I say roll out lots of EVs even in dirty states.
    Incrementally I would advocate for the new additional power needed in those states be clean. A net win, IMO.
    Mike
    Trollbait, Zythryn and austingreen like this.
  9. Trollbait
    12,543
    Considering plugins emit less CO2 in dirty states than the average emitted level of all new vehicles sold, rolling them out nationwide will help lower transportation GHG emissions with improving the grid.
    3PriusMike, austingreen and Zythryn like this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is part of it. The main point is the assumption that adding renewable electricity to the grid, somehow entitle you to claim of receiving a clean renewable electricity. It could be wasted, go to someone else, may never come to you, etc... all depends on the time of usage and other variables. I think the "buying green electricity" is a scam. It is advertised as you would be getting it when you are only paying for it.
    So, everyone gets to claim (at least partially) using that clean renewable electricity. That is my point. You paid to add more renewable electricity to the grid but so does everyone else. There is a renewable energy fee in NY/NJ electric bill. I would assume it is true in all the states.
    I'd say roll them out even in EV dirty states too but don't reward them with $7,500. 36 MPGe EV does not deserve it when there are 50 MPG regular hybrids. That is the wrong message to send.
    Instead, $7,500 can be used to clean up the grid. It will result in cleaner emission. There is no need for you to advocate.
    Clean grid should be the horse and EV be the cart. Horse will pull the cart. The cart in front of the horse wouldn't work - simple as that.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    YES
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    I understand and agree to the uncertainty.
    But just as a theoretical argument, if I produce 1 kWh of clean electricity and send it to the grid, and the grid produces 1 kWh less fossil-fuel based electricity as a result thereof, how would you describe my contribution ?
  13. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    36 MPGe EV? A full-sized Proterra electric city bus gets 20-30 MPGe. An EV pickup or minivan would get 70-80 MPGe.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You initiated the path to reduce 1 kWh fossil-based electricity. The end result is only reached with many other's contribution (including the need of fossil fuel reliability) using public infrastructure.
    You get the credit for the initiation but not for the end result. Remember, we need fossil fuel in the mix, in order to make it work. That is until we have the energy storage capability cheap/practical enough to totally move away from fossil fuel.
    There are states with 34-36 MPG equivalent.
    #74 usbseawolf2000, May 8, 2015
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ I cannot see the utility of your reasoning.
    As an example:
    A village in the desert runs out of water.
    You trek across the desert and bring back water that is stored in local containers and then consumed by the village while they wait for you to go get more.
    Without your effort, they all die of thirst. True, they say; but if we did not have containers, or decided not to drink your water, it would not have value. So the village deserves the credit for the end result.
    Huh
  16. austingreen
    13,675
    4,213
    Austin, TX, USA
    There are good programs and bad programs. In texas we have the choice program, the choice customers pay more and the power gets built. The net renewables are credited to those paying for them. In NY/NJ there are renewable surcharges but this only is what is legislated, that is not a choice program. The program in ercot is much more successful and that credit is part of it. The eastern grid has a lot more problems though, making choice programs less effective than in the western grid and ercot. First the grid infrastructure in New York is rather poor for adding wind, and there is not much political will to even improve it enough to prevent black outs. Having a good infrastructure is necessary to allow small operators to quickly add resources and provide this choice to customers. Then you need to be able so to have access to good renewable resources, which exist in NY/NJ but they are not as good, making them more expensive than in ercot and the western grid.
    I'll give you an example of a bad NY program. I recently attended an convention in NY State and you could pay more to offset your flights and electricity there with green energy. The money though didn't go to build near the convention but in arizona for power to be exported to California. It looks like the renewable credits would be sold to you, then the power stripped of credits sold to SCE that already has a RPS, but this other energy would likely have them build or buy less. Unlike green choice in austin that actually provides all the net green energy, there was no way to tell if you were even buying any more production or not.
    Colorado is a "dirty state" but has excellent choice programs to build wind. What if that dirty state leaf or i3 owner pays to buy wind turbines? Colorado wants the cars and the green energy. Why should the state taxpayers pay for the subsidies, and not get them? I mean that leaf even without the wind produces less than half the ghg as a tundra, and with the wind a lot less ghg than a prius in new york. Seems arbitrary, but I guess that is what politics is all about, and you really don't want to help this plug-in tech reduce osts for the future. Lots will politically side with you, but lets not pretend that bev in colorado is all that dirty or doesn't help reduce oil imports.
    There are separate programs for that, and the federal budget is much higher for those. Likely cuts to those programs would be on any congressional bill to cut plug-in subsidies.
    I think we are past buggy whip days.
    RPS are less effective and more costly than choice programs for electricity, but they keep more power for the big utilities and the PUCs and the EPA, and often that is more important politically than actually cleaning the grid. Reducing coal use on the grid is happening, but could be happening much faster with better public policy. Some taxpayer money is used to keep coal on the grid, mountain top removal despite its destruction of jobs and the environment is protected by congress to ensure more coal is mined more cheaply with fewer workers. Those seem like a better subsidies and pollution problems to attack than that of plug-ins or even keystone.
    At the same time it will take decades for plug-ins to become a large percentage of transportation. If the grid doesn't clean up by then, there is no way the country can meet it's ghg goals. If it does clean the grid then the plug-ins in 20 years will pollute much less than today. Why stall plug-ins to keep an oil and biofuels only transportation infrastructure. Progress takes time, and waiting for the perfect because some claim the good isn't good enough is a stall to progress.
    #76 austingreen, May 8, 2015
    Trollbait likes this.
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    If I may refine the analogy. Villagers were drinking muddy water but you go up the mountain to release some pure water. They only get to drink a blend that is cleaner. They won't die if they don't get cleaner water but your effort do add value.
    The credit for the end result should be shared. You should get more credit because you drunk pure water when you were up on the mountain (and the blend when you get back).
    Give incentives for "buying" wind turbines, not when they buy Leaf or i3. What if a home owner without plugin car, also want to "buy" wind turbines? Why should only car that use electricity get the incentive? Anything that uses electricity in Colorado should.
    Tax payers are footing the bill too with government the incentives. Everyone pays the monthly service charge to maintain the grid infrastructure as well. It is not only about the initiator.It is everyone in the gird.
    #77 usbseawolf2000, May 8, 2015
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    Who gets the credit for the villagers now having a cleaner water supply ?
  19. Trollbait
    12,543
    If it was the desire for the personal kudos of using sustainable electric for their home or car, I say let them. There is more incentives beyond financial to getting people to help clean up the grid or even improve their energy efficiency.
    Compared to the typical new vehicle sold today, a plugin emits less CO2 everywhere in the US. Maybe they emit more than a Prius in some areas. The Prius sold maybe 140k units last year. The Camry, not including the hybrid, sold 350k plus. The F150 sold over 700k. The few plugins bought instead of a Prius in a 'dirty' state, will easily be covered by the ones bought instead of a V6 sedan or worse.
    It will take time before plugins to have an appreciatible impact on fleet emissions. New car technology simply isn't as embraced by the public in a short time like it is with phones. Delaying plugin introduction until the grid is clean enough will just delay the positive impact plugins will have on fleet emissions by that adoption delay. The majority of people aren't going to buy Prii during that time, but a non-hybrid that will likely emit more CO2 than the plugin.
    So offer the plugins now. Compared to the typical car that would have been bought in their stead, they still emit less CO2. For the few that are bought instead of a Prius, the numbers sold due to the adoption lag will be small, and have a smaller impact. So the 'harm' of selling a plugin in a dirty state is tiny. The grid is getting cleaner. By getting the plugin adoption phase out of the way now, means they will be selling in numbers to have a real effect on fleet emissions when the grid is better.
    A home windmill electric system already gets (or got, I forgot if they expired or not) the same 30% of equipment and install cost as a tax credit as a PV, solar hot water, or geothermal heat pump got. The $7500 was only 18.75% of the Volt's initial price.
    There is also incentives and decentives on the commercial side to prod the utilities to greener power. The bill that gave the tax credits to plugins had an increased excise tax on coal.
    The guy that didn't piss on all the improvements being done?
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You do. That's different than you claiming you are drinking only pure water.
    The appliances need to be Energy Star or some type of result that shows higher efficiency to reduce emission. The energy system you listed are guaranteed to use/generate renewable energy.
    $7,500 Volt tax credit simply relies on the size of the battery, regardless of efficiency or emission. If there is a guarantee that plugin owners only charge from renewable electricity, $7,500 incentive can be justified, but it is not.
    Again, why do we give out $7,500 in dirty electricity states?
    #80 usbseawolf2000, May 8, 2015
