Netbook or iPad in Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by web1b, Apr 30, 2010.
  1. web1b
    web1b Active Member
    817
    52
    That doesn't seem to make sense. How much power does the iPad need to charge over USB and how much charging power is available from the Prius USB port?
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Mine will never fit; it's the 64GB model. ;)
  3. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Innovate Motorsports OT-2 - Transform your iPhone or iPod into a wireless gauge, data logger, dyno, efficiency meter and OBDII scan tool.
    So much for that.
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    The iPhone is still limited to one app at a time. With an xp or linux box you can have a software radio, gps, OBDCII app and many other things running at the same time
  5. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    iPhone OS 4.0, which is coming out this summer, will be able to run more than one app at a time. BTW, the iPad isn't a closed platform. All the apps are written by third party, not by Apple. The only thing Apple does is make sure the apps are not buggy and doesn't render a customer's iPhone/iPad unusable. Quality control.
  6. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    This will officially change in the next version of the iPhone OS.
  7. Judgeless
    1,821
    257
    Cleveland, OH
  8. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    I think judgeless is running out of ammo to shoot down the iPad/iPhone.
  9. paulemus
    paulemus New Member
    93
    San Diego
    It is very tempting to play with gadgets in the Prius. But I totaled my Gen2 Prius while messing with my iPhone video. Totaled another car and I'm lucky I didn't kill the woman and two girls. You people need to take distracted driving very seriously. It is not worth it. Keep your eyes on the road. Just ignore the gadgets if necessary, and remember to concentrate on job number one. It is extremely serious.
    2 people like this.
  10. Gilbert
    Gilbert Member
    255
    i have an ipad car charger, but i dont use it while listening to music on the ipad because as soon as i plug the power, it creates noise which is kinda anoying. havent found a way to get rid of the noise....
  11. web1b
    web1b Active Member
    817
    52
    Have you tried seeing if it will charge with the in-car USB port? If it does, that might not create noise.
  12. Gilbert
    Gilbert Member
    255
    oh i dont have a 2010, im just saying i got one of those chargers they were talking about and get noise from them :D
    but then again ive gotten the same noise when i charge ipod in a different car too so.. i do not know
  13. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Not to get off topic again but that's a sick setup you have there! :eek:
  14. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    That noise you're referring to is a problem in the 2006-2008 Prius models. There was a TSB to get it fixed. If you're still within 36k miles, you should be able to go to your dealership and get it fixed.
  15. mitcheli
    mitcheli Junior Member
    39
    2018 Prius Prime
    I can speak somewhat on this topic. The iPad WILL charge using the AUX port in the center console of the Prius, but there's a catch. The power coming off that port is 500ma, the same as a standard USB port on your computer. The charger that comes with an iPad puts out 2a, or about 4 times as much power. The iPad will charge off a 500ma source, but only with the screen off and it will take a very, very long time to charge. I find my iPad will charge about 50% in full 8 hours, or so. If you're looking for that 2 hour charge time time that you get with the factory charger, be on the look out for a 12v car adapter that's capable of putting out 5v @ 2a. Otherwise, pick up a DC transformer to plug the factory charger into. As posted elsewhere on this board, you can fine some here: http://www.griffintechnology.com/device_types/ipad
    Personally, I find the AUX port sufficient on long drives to other cities. It will maintain a charge for screen-less Pandora streaming. (Duly noted where AT&T service works along highways, else, it's my Sprint phone that provides the tunes...)
    The AUX port also doesn't create any noise from what I can tell. The Bluetooth connection is pretty clean, and sounds very nice.
    Now, another interesting point is that the NAV system, which has iPod capabilities utilizing the USB port are not compatible with the iPad. The NAV system doesn't seem able to load the file system as it otherwise would be on an iPod. Furthermore, the iPad complains that your car is not compatible.
    But there is a resolution to this problem. Albeit, a bit more limited. All iPads come standard with Bluetooth, and it will sync nicely with the Prius as a multimedia device. Plug in your aux port, fire up Pandora, turn the screen off, and hit the road. (Or tossing it in the back for the kids to play with while they watch their favorite iTunes shows on the long road trips, etc)
    As for storage, not sure if it will fit in the top glove box, I'm wagering not. It'll fit in the lower one, but you can also easily store it under a seat as well. It should be noted that the iPad doesn't like operational temperatures over a rather low temperature (90 degrees or so?) so if you intend to store your iPad, then I would expect a far shorter life...
    It should be noted that I am strictly referring to the plugging in of the AUX port in the center console, not the $300 ipod plug they sell separately as a connectivity kit. I have no experience with that set up.
    Hope I helped on this one.
  16. meduel
    meduel New Member
    Israel
    Check the new Prius with iPad & iPhone 4 mount!
  17. meduel
    meduel New Member
    Israel
  18. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    Instead of a car charger, I have the ZaggSparq ZAGG | ZAGGsparq 2.0 | iPhone Charger | iPad® Charger | Portable Battery Charger for my iPad. It lets you recharge anywhere.
    I like my iPad very much, especially with the new OS that allows me to organize apps in folders. Running only one app or internet session at a time is probably the biggest drawback. Nevertheless, I can't remember the last time I fired up my laptop. If only I could get my iPad away from my granddaughter........
  19. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Smartest post in this whole frivolous thread!
    Leave the Ipud in the case...
    Just drive the damn car... that in itself is hard enough.
  20. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    I find that my iPad fits nicely in the gap between the shifter and the middle arm rest. (OK, you can't shift the lever down at that point... it's a tight fit.) Just as an iPhone fits very nicely in the opened front cup holder, with the bottom of the phone on top of the front of the holder and the top of the phone resting against the flipped-up cover.
    Coincidence? Probably.
