Never rotate your tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jayrider, Sep 30, 2010.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    It wouldn't double their tire sales, but it gives the shop twice as many opportunities to try to upsell -- brakes, alignment, suspension parts, etc.
  2. JimboK
    2,817
    190
    49
    Chesterfield, VA
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    You would probably miss out on some decent sales and rebates only getting 2 at a time as well. It seems there is ALWAYS a rebate going on if you buy 4 tires at once or if you go to Pepboys you might get the buy 3 get 1 free "sale".
    I agree it wouldn't double their sales, but it may result in a little more revenue depending on timing of sales for the tires and as Jim stated, more chances to upsell.
  4. Jim05
    Jim05 Occasional Quasi-Hypermiler
    115
    Culpeper
    I haven't bothered rotating mine since 15k and at 37k still have even wear all around. Based on the tread depth, I'll probably get to 50k very easily without a rotation. I'm with other posters about just banking the money toward a new set, probably just before we hit winter or earlier if there are some good sales/rebates.
  5. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    I guess we're a little off topic but... real damage can be done to the drivetrain of all wheel drive vehicles if one tire's diameter is out of size with the others. Even tire shaving of a single new tire is suggested to equalize the 4 diameters to prevent a problem (and waste good tread :mad: )
    :focus:
    With all the info here an owner needs to think about what they are doing and DRIVE SAFELY ;)
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Thanks for helping out with clarification. I used 'tire installer' instead of tire retailer. Sometimes they are both the same. It would not double tire sales. It would double their service (rotation and installation) charge since you visit them twice often.
  7. RRxing
    RRxing Senior Member
    2,561
    1,837
    NEPA
    Really - If I don't rotate my tires how will I ever get any wear! (bad pun intended)
  8. FlycatchR
    FlycatchR New Member
    PA
    ...unfortunately the stability in the drive dynamics are determined by the rear tires and this is where the best tires should be. When the front tires lose their traction, you might not be able to accelerate properly or you will understeer in bad weather conditions, but you will never lose stability and get to a critical point where you might lose control over your car that you are not anymore able to control...Therefore it makes perfect sense ;)
  9. FlycatchR
    PA
    ...the stability in the drive dynamics are determined by the rear tires and this is where the best tires should be. When the front tires lose their traction, you might not be able to accelerate properly or you will understeer in bad weather conditions, but you will never lose stability and get to a critical point where you might lose control over your car that you are not anymore able to control...
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    People are saying to put the best tires on the rear, yet it's almost always recommended that a donut (temporary spare tire) be put on the rear?
  11. snead_c
    667
    58
    Hendersonville
    Donuts are only for getting you to a service station. When you have a flat replace the flat with a donut and drive slowly (usually there's a recommendation here in the owner's manual) to the nearest repair facility. I would never attempt changing a flat front tire by moving the tires around to allow installation of the donut on the rear. With my luck I'd end up with the car falling off the jack and , and, :eek:
  12. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    OK but somehow I doubt that selling 2 tires in March and 2 more in Sept. would be seen by a dealer as twice as much business as selling 4 in June.
  13. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Have you ever had any advanced driver training?
    I wouldn't want to be in a car with a driver who thinks a REAR wheel slide is preferable to a FRONT wheel slide.
    Understeer (front wheel slide) is more predictable and easier to correct for than oversteer (rear wheel slide).
    Understeer is corrected by backing off the accelerator, which is the instinctual response for a driver who has had no training. Oversteer require countersteering to get out of the skid, something someone with no training would not automatically do.
    Ask any professional, race, or driving instructor and they will tell you oversteer is more dangerous than understeer.
    "Fishtailing" is oversteer.
  14. paulh
    paulh Junior Member
    55
    23
    evansville,indiana
    Or do they revolve around the axle???:confused:
  15. jayrider
    jayrider Member
    163
    17
    southwest illinois
    My initial thought related to the cost of tire rotations -- $20-$30 but it seems that local tire shops offer free rotation coupons. They come in the mail but timing can be an issue so I went online and there are updated coupons for rotations on a continious basis.
    Won't need them for years but buying tires online is a great option for me. Lower price and free shipping - no tax as well. Local shop will swap them out for $4.50 a wheel including balance but I don't think they have the stick-on weights. Probably just have them mounted and take it to the local chain shop and pay $20 for the balancing with the proper weights.
    Can you use the metal weights on the inside of the rim? I have the covers off with the $4 center caps. Any thoughts?
  16. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes, I see no reason why not. My Prius came from the factory with the metal stick on weights on the inside of the rims. I think they are made of steel now instead of lead for environmental considerations.
    I had good luck with Tire Rack - Your performance experts for tires and wheels on a previous car. Had them installed by one of the Tire Rack recommended installers, no problems with that either. If you want Bridgestones or Michelins you might checkout what Costco has also.
  17. cogit8
    cogit8 Junior Member
    I recently bought 2 tires online (Continental ProContact EcoPlus, tires-easy.com, $82.70 each incl shipping, mileage increased by 1 mpg) to replace the worn front two. Since I had heard different stories, I called Walmart Automotive (who I used to install the tires, $12.50 each, includes lifetime balance and rotation), and they said their policy is always to install the new tires on the rear. Walmart said their reasoning was that having the better tires in the rear was to prevent them from breaking loose and causing a slide or spin (in wet weather or emergency situation, I suppose). Tire Kingdom said that with a front wheel drive car, they would put them on the front. Toyota service guy said he'd heard both recommendations and it really didn't matter. I wound up putting them on the front.
  18. tumbleweed
    4,067
    692
    Eastern Oregon
    If the fronts and rears have even close to the same amount of tread it really won't matter at all which end of the car they are on. This is especially true of cars that have a stability control system, such as the Toyota VSC.
    I think to much is made of this "best tires on the rear theory" considering that on dry or nearly dry pavement the tires with less tread may actually have marginally better traction. If there is standing water on the road more tread is obviously better but we all need to slow down quite a bit anyway.
    If I lived in the rainy part of the state I would replace my tires at 4/32 inch of tread, out here in the dry country I can let them get down to 2/32 if I remember to take it easy if it rains. I don't drive my Prius in the snow but if I did I think I might want winter tires with at least 6/32 of tread.
  19. Strike67
    Strike67 New Member
    43
    NY
    I
    I'm on a standstill with this one haha.
    I think i'd rather have oversteer than under steer. The reason being... say you're comming up to a bend.
    You under steer.... the car keeps going head first straight at an angle into the tree.
    You can over steer... the car does a 360 or so but most of the kinetic energy is brought into the spin, slowing you down a great amount. So can stop before you even hit the tree or... you slow down a great deal before you hit that tree and be okay.
    I speak from experience in trying to make my car spin out to test how it would fair in real conditions. and of course with a general knowledge of physics :)
  20. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    The thing is when you understeer you tend to let of the gas and most of the time you regain control of the car. When you oversteer or the rear end starts to slide out most of the time it's out of your hands what happens.
