New 1 week old blower motor smoking and melting plastic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Metaldrummer13, Jun 4, 2020.
  1. Metaldrummer13
    Metaldrummer13 New Member
    Louisville KY
    I had been trying to troubleshoot my AC problem, first buying a new blower motor resistor to no avail, then bought a new blower motor and replaced that. It worked great up until yesterday when I noticed a burning smell, then a little bit of smoke. After sitting idle for a few minutes to drop off a delivery, the vents shot out a cloud of smoke which was beyond frightening. Few videos I watched on YouTube downplayed the severity as this seemed to be a common issue regarding the dew point or humidity coming in contact with hot/cold air or something to that extent, but given the recent motor install I was worried it was something more. Sure enough when getting home I had taken out the blower motor and it had started melting some of the plastic casing and possibly something within the cylindrical part. Granted I bought the cheapest blower motor on amazon, but I’m afraid there’s some sort of larger electrical issue I’m not versed in solving. Judging from this and these pics, does anyone have any helpful info? Also at 275K on an 07’ if that helps diagnose more, thank you.
  2. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    One will assume that you have no OBD2 codes (DTCs) that you can share with us here.
    The only real expert on the subject that might be able to shine some light on this problem would be @lech auto air conditionin - highly recommend following his posts and searching out his videos to watch as well.
  3. lech auto air conditionin
    830
    601
    260
    san francisco
    I got to say i never came across smoking blower motors in Prius before. Living i San Francisco with mild weather avg 68F and we consider 75F hot weather with little humidity @ 80F we are dying here. I know DENSO blower cost more see if you can find one DENSO motor online or parts warehouse. did someone install a larger rated AMP fuse ?. If so put back the OEM rated fuse. sorry I can't help you on this one.
  4. dolj
    dolj Senior Member
    7,508
    3,773
    Wellington, New Zealand
    This could be your problem rather than any other electrical fault, assuming you've checked the circuit fuse, as advised by Lech, and the correct rated fuse is installed (and not blown).
    As Lech said, try and find a genuine Denso replacement or just get an OEM. If you use quality parts, you shouldn't be replacing this again anytime soon, so just spend a little extra and save yourself the grief.
    SFO likes this.
  5. ChapmanF
    15,108
    Nope, that is not something I would expect from a good quality part.
    Having now let the magic smoke out, I would be a little concerned about the controller also (which isn't a "resistor", those went out years ago, it is a transistorized pulse-modulating controller and this episode might not have done it a lot of good, assuming it was good to begin with). Was that also an aftermarket version?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    yep pos motor. When I replaced mine I made sure it was an OEM. 6 years later still working. I wasnt going to lay under there and jack up my back to put a pos motor in it.
    I dont put anything aftermarket in my car its waste of money its all chinese crap including your motor. Suspension parts are the worst.
  7. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    erm, why not use parts from a junkyard? I'd expect that to save a lot vs. new OEM.
    edthefox5 likes this.
  8. edthefox5
    10,096
    4,795
    Clearwater, Florida
    yeah my back would love doing that twice but junkyard parts make no sense to me there in a junkyard which means they have been running for years and years already especially an electric motor. And that motor may be blown too.
    I did buy wheels there after my wife destroyed them all and crossed my fingers they weren't bent too. Got lucky they weren't.
    Down here its impossible to drive 3 miles without ac. And forget windows down in the G2 the G2 makes a deafening noise with its windows open. Unbearable vibration.
    But thank you though.
  9. ChapmanF
    15,108
    The OEM blower (motor with impellers attached) is just around $120 at online Toyota dealers. I'm not sure that would cover my time to go find a salvage yard and pull one.
    It's that PWM controller that is pricier. On the other hand, it's solid state electronics, and probably ok in a salvage Prius regardless of mileage (unless it had to endure a smoke-bomb motor attached to it).
  10. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    Car-part.com lists a few dozen, already removed from the cars, in Kentucky, for between $35-80.
  11. ChapmanF
    15,108
    Did you see prices for that PWM controller there too, 87165-47020? That's the salty bit.
  12. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    I did not see an entry for it in the search form. But car-part is mostly a matchmaker service- I bet @Metaldrummer13 could get on the phone with one of the yards listed as selling the blower and just ask the guy (who probably knows the database better than myself) if they have the controller.
