New 11 prius battery problems. Need advice.dr pruis test run 48%
Discussion in 'Gen 3 Prius Main Forum' started by bobby515, Mar 17, 2024.
  1. bobby515
    bobby515 Member
    181
    phila
    No coolant leak yet. Maybe compression. Engine runs fast . Good power
  2. bobby515
    bobby515 Member
    181
    phila
    If I will keep the car only 9 months. Is it worth a shot of 1k for rebuilt with 12 months warranty. I will not keep car long. I need more space like a camry
  3. Tombukt2
    Tombukt2 Senior Member
    12,987
    2,328
    Durham NC
    You're going to Uber the car and things like that probably really not worth it to fix it up to tough door panel armrest cave in now you're going to be carrying passengers in the rear and they may cave in can't get any replacements glues don't hold the plastic plastic welding doesn't seem to work too well various other plastics will fade and fall apart relatively quickly after 2010 You may not be able to Uber or do anything in an '09 because well they force you to get a newer car although driving in HEV they shouldn't ding you for that as far as I'm concerned My wife got around that by bringing that up with Uber and Amazon flex and all them and they gave her a pass. The three is not the car to be pouring money into because you'll never have anything for your money or if you do it'll be very short-lived generally speaking these cars are not designed for this kind of duty we're an '09 will eat it alive this kind of duty but a 2010 Plus not so much and you're taking more humans
  4. Mendel Leisk
    41,456
  5. bobby515
    bobby515 Member
    181
    phila
    It's an 2011. No problem with arm rests. Least of my problems. Either flip to a dealer for 3k as it runs great and looks great. I paid 6k. In June as in PA car prices are still hi.
    Add 3k maybe if lucky a corolla..
  6. bobby515
    bobby515 Member
    181
    phila
  7. bobby515
    bobby515 Member
    181
    phila
    I will clean it. I have a weak battery as per Dr pruis. The bad test was last night. In warmer weather battery seems better.
  8. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    Run the Prolong system on it.
  9. bobby515
    bobby515 Member
    181
    phila
    What's that.??
  10. ASRDogman
    7,591
    3,916
    bobby515 likes this.
  11. rjparker
    rjparker Tu Humilde Sirviente
    10,151
    6,308
    Texas Hill Country
    Click your pic or name to find “Recent Activity”. Works on others as well.
  12. Tombukt2
    12,987
    2,328
    Durham NC
    I've got two of them here and all that stuff inside is falling apart All I'm saying is when it does when you go to the junkyard to find parts they're all broken the same way so you're stuck buying new a new center console lid a door panel in the armrest caves in and things like that are quite costly like those two parts would be around $550 bucks unless you got really lucky or something. I mean I've driven cars so long I've been sitting on seat frames before I know a little bit about it.
  13. bobby515
    bobby515 Member
    181
    phila
    Thanks, for all the advice, i got the car in june with 192k, have 201k now on it. interior good body good. everything works new tires.
    when the car was brought 6k as cars are hi here. so many of these around.
    it had a small vibration at take off in eco mode. like a bad coil. cvc shalft or motor mount. i got avg 39 mpg, when warm out higher. in sunner last year on long hot roads of 35 mph, i hit 50+.
    i read up EGR carbon's . did the intake only. motor got smoother but not perfect. put 8k on uber,car has power. and smooth idle. now
    when the motor kicks on some rattling..i have that pruis bad engine noise before cleaning the manifold. it fixed the major noise than now it does a small vibration.
    no coolant leak's.
    my battery charges up now very quick and than looses charge fast.
    no check engine lights or code's.
    i see when battery gets low. motor has some small power lose . or vibration..did not have this before.
    ok my choices. 61 years around cars.
    #1 sell the car to trade in add $3 k get a gas car. used are still really hi cost here for hi miles cars.
    # 2 right away clean the egr- clean cooler, prepare for a head gasket and timing chain. also water pump while thier. and fix the battery $1000 or so or just drive it to the lights come on. engine uses no oil in 5k. the recon of the battery may be headache for me.
    the steering is good. suspension decent. tire wear good. only problem is the size is small. gas per week is great..$25-$50.
    sorry if i am over and over new to the site. has alot of toyota's all gas.
    i posted on my phone big mistake. either way today 2" of rain but during the week . i will clean the cooler and EGR. anyway. cheap and simple.
    thank you all for any advice. has to rid the car of 200k to buy a headache at gas model $5000 140k miles or more, in pa here cars are we have alot of junk yards here for parts if needed. the avatar shows a bad rear bumper rt. side. got the new one painted in my garage..must push out area of taillight a small amount..easy..i am more body guy than engine guy..but 3 years of tech school and 15 years at dealer doing body work not mechanical.
    thanks again..i not know much about this cars. but i think cleaning the cooler and EGR will help some..tks
    bob.
    hi guys after looking at used cars $5000 here buys me crap. this car is worth a $2000 investment if need be at this time as tax season destroys cheaper cars.
    so deal with battery last. clean egr and cooler now. plan on head gasket water pump and timing chain is i do the gasket..no sense leaving a 200k chain with a new head gasket..this car has been earning me an income for 10 solid month's no troubles..
    #33 bobby515, Mar 23, 2024
  14. Tombukt2
    12,987
    2,328
    Durham NC
    PA USA is rust area so car should not last to to long we've done similar to these models.without great success. So now they're like playground equipment . The children love them . Kinda disappointing after driving Toyoda for 40 some odd years. But they are par for the course of manufacturing today . Companies need folk now that know nothing of the past . . These companies are pretty smart.
  15. bobby515
    bobby515 Member
    181
    phila
    I got like 5 in a 2 block are all area hi miles. One like 320k.
  16. bobby515
    bobby515 Member
    181
    phila
    In Philadelphia. It's not to bad on rust. I have none on any of my cars. Just never let salt or road trash never sit on the body.
  17. Tombukt2
    12,987
    2,328
    Durham NC
    I've got hundreds in a 5 mi area oh I don't know 40 of them are probably broken maybe more and then the tow lots have made a few in each of them but that's good you're ahead of the numbers game so carry on Good job.
  18. bobby515
    bobby515 Member
    181
    phila
    Respect to the senior member. Are you saying these cars are bad.??? I worked for Toyota sales a long time in Florida. Always great cars
    Just back from the Philippines. They use for 6 passengers Toyota rush.. like rav 4..
    Maybe it's just the pruis.
    I will gamble on high Mike's Toyota instead of a dodge dart or chrysler 200. Just saying..
    #38 bobby515, Mar 23, 2024
  19. Tideland Prius
    16,557
    Merged threads
    Mendel Leisk and Brian1954 like this.
  20. bobby515
    bobby515 Member
    181
    phila
    Update. egr valve stuck open with carbon. cleaned it and cooler. replace spark plus awhile back . all looks good.
    car in econ mode runs faster and more power. the car always had great engine power.
    the bad. once i had that nasty engine noise . i cleaned the manifold . never loud again.
    but...but..always had a small vibration as engine starts..like a mini noise of the big noise.
    i think a few things..no coolant leak's
    coil's packs maybe..injector's maybe
    last compression loss from bad head gasket...
    overall the car in 5k + miles @200k burns very little oil. half court.
    a few question's if head gasket is bad and you got great power . and good idle, do you guys just replace the gasket or send head out.
    reguarding gasket and timing gears.
    does any one just buy the felpro head gasket and get the whole kit ckeap with aftermarket gaskets and buy 1 felpro.
    what can i do to check coil's..on my nissan if 1 was really bad..you knew it. i think as 9k on the car myself. maybe a weak coil but under a load. its great..
    how can i check injector's.
    and the small virbration when starting up..very long time it has been doing it...can it hurt the engine..can i do a regular compression test on the engine in maintaince mode.
    i am not keeping this car longer than say christmas,,no codes or lights on.
    thanks for any input.
    as far as the battery. i will worry that later..drove today fixed sunday. want to see if mpg is better..it has to be avg 38-40 running it hard in power mode.
