New 11 prius battery problems. Need advice.dr pruis test run 48%
Discussion in 'Gen 3 Prius Main Forum' started by bobby515, Mar 17, 2024.
  1. bobby515
    bobby515 Member
    181
    phila
    hello is this good for dr pruis 40% battery bad?? must you remove the battery.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,151
    6,308
    Texas Hill Country
    For a Toyota, gen3 Prius are undoubtably the worst in thirty years. Bad rings, inverters and brake boosters combined with the expected hv battery after 150k miles make a high mile used car gen3 a bad bet for a budget conscious buyer. It is especially bad when a high market is getting x2 the price of four years ago, flippers will rollback odos and use temporary head gasket sealers, most hybrid parts have no aftermarket options and many areas have few independent mechanics who will work on them.
  3. bobby515
    bobby515 Member
    181
    phila
    so you are saying dont do a headgasket myself if needed..dont check the coil pks or injector's. if i sell this good running 200k car for 4000- i must pay $3000 more to get someone's else's junk in philadelphia. cars are so hi here...let me play along. i put say a new head gasket and water pump.. $600.
    replace rebuilt battery 1000
    used invertor and abs unit if needed. still the car will be ok as per getting another car. body seats overall cond good. so you think its better to dump this toyota??????????????
  4. rjparker
    10,151
    6,308
    Texas Hill Country
    You asked if these cars were bad. I mentioned the issues. Including what flippers do to unsuspecting buyers. In your case you are trying to flip the car.
    bobby515 likes this.
  5. bobby515
    bobby515 Member
    181
    phila
    No I am not flipping it I am an uber driver who wants to drive the car. Only problem for me it's alittle old at 2011 and at 61 alittle to small but if any positively of the car. I will keep it. Body good. Suspension good . Clean interior. This forum has got me worried about the car.
    Please reply as worst case if I want to keep it 1 year.
    I am not a flipper. I am an owner.
    I worked for Toyota a few years in Florida.
    Had at least 5 of them. 2nd pruis.
    1st was an 08. I got to sell. 308k .
    Can you put a pros and cons to keeping it....I been earning money with this car since the day I got it June cost $5400 plus . Plus
    Normally $3000
  6. rjparker
    10,151
    6,308
    Texas Hill Country
    Just read my reply in post 42. In your case you are already set in your mind. Sorry.
  7. bobby515
    bobby515 Member
    181
    phila
    New member
    How do I see post 42 ?
    i been on an uber driver forum 11 years, i help people all around the world. i respect any advice or help.i did black suv. and wheel uber /lyft in my city..
    #47 bobby515, Mar 25, 2024
  8. bobby515
    bobby515 Member
    181
    phila
    I am not set. this is why i am here, for some help...i am 61 owned over 100 cars in 42 year's.
    that cooler stud kicked my nice person as my hands are big..after that it was cake.
    now i see how it works i read your comment's thank you...
    head gasket set for Prius - Google Search
    2010-2019 Toyota Prius Timing Chain - Autopart Premium APTCK216 - - PartsGeek.com
    are these bad..i know used felpro for the head correct
    #48 bobby515, Mar 25, 2024
  9. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    I do no know anything about that doctor.
    I use the Prolong system and have not had any problems since.
  10. Mendel Leisk
    41,456
    The part no's for Toyota gasket kit (includes head gasket, and pretty much everything else pliable in the engine), and the head bolts, is noted in the attached.
    Also not: the last link in my signature is the full engine section of the Repair Manual. (on a phone turn it landscape to see signatures)
  11. bobby515
    bobby515 Member
    181
    phila
    When you used it how beat was your battery, as I been looking at them
  12. ASRDogman
    7,591
    3,916
    I have no idea. I noticed it took a while to go from 2 bars to 3, then quickly went to
    3, then 4. And quickly went from 3 to 2 bars.
    This was one of the issues of the battery getting weak. So I purchased the Prolong system.
    And it worked for me. It was well worth the money, for me. The battery is 14 years old and
    still working.
    I know it won't last forever, but it sure hase extended it's life.
  13. bobby515
    bobby515 Member
    181
    phila
    I looked at it looks good. Seen some YouTube videos on it.
  14. bobby515
    bobby515 Member
    181
    phila
    results after morning 50 miles . improved power- with egr and cooler cleaning..mpg better at 43- as per 37.
    vibration when shut off, i think is a weak coil or injector,,i think the future can be head gasket not now...but battery at bad 48 % needs attention. been watching vids on prolonging it with equipment..
    cooler torq bolt kicked my - - -..hands are all beat up,,trouble with gloves..all my younger life i had these hands to big problem..shoe size 13
  15. ASRDogman
    7,591
    3,916
    Looked at what????
    "I looked at it looks good."
  16. bobby515
    bobby515 Member
    181
    phila
    the charger videos
    ASRDogman likes this.
  17. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Hey,
    The Prolong systems don't require you to remove the battery. They come with a harness that plugs right into the OEM fan and the positive and negative terminals on the battery. It takes a couple of hours to access the battery, install the harness, and put some of the interior back together again but after that, it's a pretty easy product to work with.
    Garrett
  18. bobby515
    bobby515 Member
    181
    phila
    Tks. While using . How does it work. You install and complete it than drive the car or in steps...
  19. ASRDogman
    7,591
    3,916
    I have to disagree, it won't take a few hours to install. Less than an hour.
    It would be nice if the cable was about 12 inches longer though.
    It's just long enough to attach to the charger and discharger. The extra foot
    would help a lot. (y):whistle:
  20. ASRDogman
    7,591
    3,916
    The instructions will tell you what to do.
    After it's installed, you plug in the charger and fully charge the battery.
    Then unplug it and plug in the discharger, select the 1st cycle and start the
    discharger, then charge, discharge, charge, discharge, then charge.
    Mine averaged 4 hours for each part, with the longer discharge then charge
    cycles each taking a littler longer. If you keep an eye on each cycle, you can
    do it in 2 days, but 3 is more realistic.
