New 11 prius battery problems. Need advice.dr pruis test run 48%
Discussion in 'Gen 3 Prius Main Forum' started by bobby515, Mar 17, 2024.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,151
    6,308
    Texas Hill Country
    If you want to partially restore your old hv battery you should individually test each of the 28 modules and then replace the weak modules. These modules are wired in series to provide the nominal 201vdc. A set of series battery moduleswill be limited by the weakest, lowest capacity module(s).
    This video takes you completely through the process. Note how many of the modules he replaces with better used modules.
    #61 rjparker, Mar 26, 2024
    bobby515 likes this.
  2. bobby515
    bobby515 Member
    181
    phila
    Perfect thanks.
