New 12V battery but car won't start
Discussion in 'Gen 2 Prius Technical Discussion' started by Macky Hlaiki, Jul 18, 2023.
  1. Macky Hlaiki
    Macky Hlaiki New Member
    Skokie
    Three Touring
    I replaced the 12 v battery 6 months ago , I left the car sitting for few days when I tried to start it, the car was dead( no lights,) so I jumped up it. Took the car to check the battery , 2 places said the battery was good. This started happening very often like every other day, everytime I take the car to check the battery it comes out good no issue ( good battery) ( no check engine)
    Now the car will never start without a jump....
    Can u plz help me figure out the problem
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Recheck the replacement work, some of the connections might be loose or corroded, including where the ground straps at the body.
    FYI : you're moderated until you've posted 5 times.
  3. Macky Hlaiki
    Skokie
    Three Touring
    Thank u for the reply
    What do u mean by replacement work ??
    52,861
    Sounds like you have a drain on the battery when the car is off
  5. Macky Hlaiki
    Skokie
    Three Touring
    Yes, but how do I find out were the drain is , there is no check engine light
  6. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    The work you did when you replaced the 12 V battery 6 months ago.
  7. Mendel Leisk
    42,352
    Check the battery’s connections. With a volt meter, first check voltage between the two battery posts. Then check voltage between bare metal of the car body, and the jump start terminal in the fuse box in the engine compartment. If the second check shows much lower voltage there’s likely a poor connection in the wiring.
    Doug McC likes this.
  8. Mendel Leisk
    42,352
