New 12v battery installed...now master key won't function
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by databell, Jun 2, 2011.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    CR2032s are 28 cents apiece from Digikey. You better get a bunch of them for $3.
    Tom
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Wow, that's a first...I'm pretty impressed that the mechanics figured that out so easily.
  3. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    If the buttons get jammed, consider getting a used fob on ebay and switching over all the electronics over from the stuck fob to the ebay fob case. Lots cheaper I expect.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I've never heard the bolded part before. IIRC, I was somewhere between the 3-4.x (definitely not 5) year mark before I finally need to replace my fob batteries.
    They seemed to last longer than the fob batteries on my mom's NAH (which also has a SKS system but from a TOTALLY different vendor).
  5. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    I just installed up my last CR2032 battery so I just ordered some more as I need one for my other fob for that prophylactic replacement too. Maxell x 5 with a long expiry date for US$2.79 shipped.
    I guess the benefit is you don't have to drive to the shop to pick them up. :)
    EDIT:
    I just checked Digikey for Canadian shipments. Shipping for one 29 cent battery is $8.
    "A shipping charge of $8.00 CAD will be billed on all orders less than $200 CAD*, with an additional $8.00 CAD charge for each back order shipment."
    Ouch.
    I thought I read the 1 year thing somewhere, but maybe I am mistaken. (I don't have the manual in front of me. Maybe it was for a different model Toyota, I do not know.) I do know that while many have lasted several years, one here has had to replace his batteries after just 14 months.
    As for me, I do it every 2+ years. It seems after a couple of years, the signal gets weaker. With a fresh battery, the signal is more consistent. Starting the car is still fine, but locking the car from far away becomes more problematic.
