New 12v battery, low readings
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan Romaine, May 15, 2019.
Tags:
  1. Ryan Romaine
    Ryan Romaine Junior Member
    Car died past two days in a row. Had to jump and just.got a new 12v. This morning it's showing I'm as low as 11.3-11.4 volts in standby, and 14ish in ready. Any idea ? I can't afford this stuff, man
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Always keep the vehicle "Ready" or "Off", that way the battery doesn't drain.
    How many hours per week do you drive this vehicle?
    Where was the 12v purchased, as the battery should still be under warranty.
    Ask the retailer if they charged it before the sale, or just charge it yourself.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Is my inverter coolant pump slowly failing? | PriusChat
    Read Post #5 (how to apply a load for a more meaningful measurement of 12V battery health)
    Read Post #8 (Battery SOC (State of Charge) chart and 12V AGM compatible smart chargers to consider buying).​
    Is there an aftermarket accessory that is draining the 12V battery?
    Was the dome or map lights left on?
    Was a door left ajar overnight?
    Deactivating SKS will drain the less. But, sure beats the convenience of having SKS.
  4. Ryan Romaine
    Not to my knowledge. The car was used, and all I can tell is some tint. Rest seems stock. I don't remember turning anything on, but will keep notice. Mechanic said after a week If the battery is dead again there must be something draining it.
  5. bisco
    52,862
    disconnect the 12v negative. measure the voltage at night, and again in the morning
