new 12v battery without venting tube
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by zakky, Jun 4, 2015.
  1. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The Prius c is called the Aqua in non US markets.
  2. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Have the Toyota dealer write you a letter that's is fine with no vent tube , have them sign it
    Put it with your will
    RRxing, Mendel Leisk and bisco like this.
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Aqua is water, Bisco, seriously I believe it is one of the Toyota Hybrid models, but, what do I know?
  4. Roy Lin
    Roy Lin New Member
    Currently in Taiwan
    2014 Prius c
    Auqa is only used in Japan.
    Other areas all called Prius C as I know.
  5. Andyprius1
    2,327
    859
    Cool CA
    I did this, and died .............my maker still wouldnt accept it. My advice is dont bring your prius to heaven.
    The devil will accept it tho.
  6. smartprius
    smartprius New Member
    CAL-ORE
    AQUA is non US Prius C
  7. bisco
    52,914
    i thought zakky said he had a c?
  8. Toasty
    Toasty Junior Member
    35
    Chattahoochee Hills, GA
    is OP still alive?
  9. CZOscar
    CZOscar New Member
    North Texas
    Hello I just found this thread after starting new thread about Prius C battery vent. My 2014 Prius C I bought used 12 volt battery died and I was unable to locate a non OEM replacement so bought new OEM Toyota Tru Start battery from the dealer this week for $213 plus tax. I am unable to locate receptor for vent tube on the new battery. Did I miss it or isn’t there one?
  10. Graham Thomas
    Graham Thomas New Member
    New Zealand
    2012 Aqua
    An Aqua is the Japanese market equivalent of the Prius C
  11. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I don't think there is one anymore. I helped the woman across the street replace the 12v in her C a couple months ago. She too got the OEM battery from the dealer here in town. No place on the battery for that tube to connect...
    ztanos likes this.
  12. Andyprius1
    2,327
    859
    Cool CA
    On my first Prius I bought a battery that was roughly the same size and electrically the same, I then drilled a hole above the correct level line, it worked fine. ( on a 2005 ).
