New 2008 prius hybrid battery needed in chicago, any recomendations besides dealer
Discussion in 'Gen 2 Prius Technical Discussion' started by John Krauchunas, May 2, 2023.
  1. John Krauchunas
    John Krauchunas New Member
    Chicago
    Hello, I'm new to this site and I am looking for a recommendation for a store or business that sells new hybrid batteries for my 2008 prius gen 2. The dealership will upcharge. Any leads is greatly appreciated.
  2. alftoy
    alftoy Senior Member
    1,132
    507
    Saskatchewan, Canada
    You called a dealer? What do you mean by upcharge?
    @nancytheprius was visiting in Chicago Nov 22 and had to replace the HV battery, was able to find a new battery from a dealer. Had to call around to 4 dealers, maybe he will be along to point you to a dealer.
    P0A80 and P3016 black friday | PriusChat
    New OEM hybrid battery - 6 months old | Page 2 | PriusChat
    Or well regarded Priuschat member @ericbecky has met Chicago Prius owners halfway and replaced their batteries.
    https://www.evpowers.com/
    Gen 2 2004 Prius 200k miles. Bad battery cells. How hard is module replacement? | PriusChat
    #2 alftoy, May 3, 2023
    Meg&Bear and bisco like this.
  3. alftoy
    1,132
    507
    @nancytheprius passed this along.
    Meg&Bear likes this.
    48,999
    projectlithium.com
  5. JDonovan
    JDonovan Junior Member
    CT/PA
    I purchased a battery for my 2005 3 yrs ago from Greenbean battery company. At that time it was $1500 and came with a lifetime warranty ( as long as I own the vehicle) they recently replaced the battery….but then I thru a rod thru my oil pan and I’m now looking for a new gas motor and someone to fix it! These cars have doubled and tripled in price in the last couple years….yikes! Good luck to us both!
  6. bisco
    48,999
    get a jdm used with low miles if you can find a mech. anyone can do it, no special hybrid models though some mechs will still shy away.
  7. Macky Hlaiki
    Macky Hlaiki New Member
    Skokie
    Three Touring
    Google Volt on Belmont he go them for $1100
  8. Gen2ChiTown
    Gen2ChiTown New Member
    Arlington Heights
    Checkout youtuber chrisfix, he buys batteries from a company called electron hybrid solutions.
  9. Classic Car Guy
    Classic Car Guy Active Member
    385
    112
    Northwest, USA
    I have a question for my 2007 prius. Whenever I have the car on a long stop lets say on a drive thru station sitting for more than 12 minutes, the battery bar goes down to the last 'purple bar' then it charges. I'm not quite sure if its suppose to go down that fastfor I cant even sit on the car longer than a normal gas engine car. Do you think there is something wrong with the hybrid battery? If so.. what do you suggest?
    By the way the car is 150k miles and its well kept and driven normally.
    Thank you!
  10. alftoy
    1,132
    507
    Search results charging in neutral
    eg:
    Battery problems in neutral | PriusChat
    Classic Car Guy likes this.
  11. Classic Car Guy
    385
    112
    Northwest, USA
  12. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    Except he's not in neutral, otherwise the car would not start the engine to charge the battery.
    Presumably you also have the a/c on and I'm guessing its quite warm out, so depending on the the outside air temp and what temp you've set for the interior temp, it is hard to say if 12 mins is bad or not.
    This is normal with the car in D. In neutral the engine would not come on and you risk running the battery to an unhealthy and undesirable low level.
    Meg&Bear and alftoy like this.
