New 2013 pip owner here w question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by arche3, Nov 7, 2013.
  1. fuzzy1
    10,687
    When a big storm is forecast, the waiting line at local shops isn't just an hour or two, it is all day. Having a set mounted on separate rims, and doing the swap yourself, means you can quickly do it when you want, not when the shop can fit you in.
    I wasn't sure, as your profile shows a 2012, conflicting with the thread title.
    Winter tire needs vary drastically with location. My experience with All Season tires in my wet but mild location is that they are adequate near home the first winter, but if run year-round, will degrade to Three Season tires by the second winter.
    Your experience of not needing better tires on your 4WD suggests a similarly mild winter drive. Many other owners drive in considerably worse conditions demanding true winter tires not only on the Prius, but on the Range Rover as well.
  2. stanwagon
    stanwagon Junior Member
    64
    2013 Prius Plug-in
    I had an 05 Prius. I live in Colo. at 10000 ft where snow and ice are huge. After 2 years with the '05 I got snow tires and it made a phenomenal difference -- 4 tires. Now I have a 2013 PiP. Sadly the wheel size is such that I cannot use the old snow tires (so we sold them with the '05). But we will soon get snow tires for the new car.
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I assume that is a typo. "You meant to say I haven't went [gone] to the has been station yet."
  4. arche3
    arche3 Junior Member
    17
    Yeah lol. I let the auto type change things.
    I used to have a jeep grand Cherokee as well. Never used snow tires on the Jeep either.
  5. arche3
    17
    Oh. Yeah I just leased the pip in October. Great deals on the car. It is a 2013 white base model. Last one on the lot.
  6. Mendel Leisk
    42,220
    I went with these rims:
    Corolla steel rim, part no: 42611-02471-SW (2007 model year?) (15" black steel rim)
    steel rim lug nuts: 90942-01007
    Alloy rims look a LOT better, but then no one knows you've got snows. ;)
  7. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Does anyone have the rim specs? I want to find another set for our PIP. Will
    114mm x 5 lug 16" 2 3/8" opening fit?
