New 2017 Prius, exhaust leak?
Discussion in 'Gen 4 Prius Main Forum' started by littlebird002, Oct 17, 2017.
Tags:
  1. littlebird002
    littlebird002 Junior Member
    37
    CA
    Just got the new 2017 Prius for about 10 days.
    Found a problem:
    every time, if I press the gas pedal hard, so it will turn on the gas engine, the sound kind of loud,
    and I can feel the gas pedal kind of vibrate. Is that like a exhaust leak on new car?
  2. Tyfly
    Tyfly Member
    65
    94
    My 2017 Prius does that too. I notice the same vibration when the engine fires up. There are a few things I had to get use to on this car. It'll make interesting noises before you start it up too.
    RCO likes this.
  3. littlebird002
    37
    CA
    Alright. Just think this is normal since it's still under warranty.
  4. first_superior_prius
    76
    114
    Michigan
    Not a problem.... just how the car is designed
    When the electric engine is on, there's very little vibration or noise because everything is coming from the battery.
    When you slam on the gas and the ICE comes on, there is vibration and noise. After all, ICE stands for internal COMBUSTION engine... you are exploding a volatile compound in order to get it's energy
    Tyfly likes this.
  5. littlebird002
    37
    CA
    Thank you for detailed explanation.
Loading...
