New 21 Prime limited commute strategy
Discussion in 'Prime Fuel Economy & EV Range' started by Boomer 2298, Jan 17, 2021.
  1. Boomer 2298
    Boomer 2298 Junior Member
    36
    Edinboro, PA USA
    All,
    I just received my new 21 prime limited Saturday. I am developing my commute strategy and have some questions. My current commute is 70 miles consisting of this:
    First 10 miles semi rural highway with some stops. Speed varies from 35 MPH to 60 MPH.
    Second 50 miles I79 to I80 80 MPH.
    Third 10 miles semi rural highway miles with some stops. Speed varies from 35 MPH to 60 MPH.
    I have tried out using EV only but I have one observation, When I travel say 8 miles in EV and switch it to Hybrid, I can not switch it back to pure EV. My initial plan was to run the first 10 miles on EV then hybrid on the highway. Switching back to EV on the final 10 miles. So this is obviously a concern. Anyone with suggestions let me know. If I can not, I will run the first 20 miles out on EV if I cant switch it back.
    Thanks,
    Boomer
  2. Tideland Prius
    16,681
    Your strategy is sound and that’s what I would do. I would warm up the engine a few miles before hitting I-79 rather than immediately when you set off (so that the engine doesn’t cool down between when it finishes its warm up cycle and the highway).
    Once you go into hybrid mode, you have to wait til the engine finishes its warm up cycle before it enters back into EV mode (even if you select EV mode and the dashboard shows EV Mode).
    Henrik Helmers and jerrymildred like this.
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    You can switch back to EV but you need to wait until the ICE warms up. Several minutes depending on outside temperature.
    jerrymildred likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Already answered by others. Do you have charging capability at work?
  5. Boomer 2298
    36
    Edinboro, PA USA
    My plan is to see exactly what fuel and electric consumption for a five day commute is. This would be currently with new Blizzak WS90's installed (have driven then this weekend to get them somewhat worn in.) Gas was topped off tonight. This of course takes in account that the weather is colder and HVAC will be used at a higher level.
    Tideland Prius likes this.
  6. Boomer 2298
    36
    Edinboro, PA USA
    I have charging capability at my plants.
  7. Tideland Prius
    16,681
    Hopefully the HV highway portion can get enough heat for the last 10 miles or at least reduce the load.
  8. Salamander_King
    11,024
    8,980
    New England
    With the use of 25-35miles EV range on both ways, if you can limit the 50 miles hwy drive speed, you should be able to get over 100 mpg. Try to use up all EV range before reaching work or home but also try not to let the engine go through the "warm-up" cycle more than once.
    Boomer 2298 and Tideland Prius like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I took a new route today to my weekly meeting and it was from home rather than the office. It's a 40+ mile round trip from home.
    To be different, I started in HV on the Prime and took SR 54 which is 50-60 mph with typically about a dozen stops over the part I drove today. I stayed in HV for the first roughly 11 miles which got me off that road and a little ways on the next road which is a little slower with no stops for several miles. At that point I switched to EV the rest of the way. For that initial HV part I showed 60 mpg. The rest of the trip in EV was 5.7 m/kWh and I got home with 1.1 miles of EV left. A pretty good guess on the timing going to EV.
    That comes to about 0.17 gallons ($0.40 locally) and $0.60 worth of electricity. Roughly $1.00 to go about 41 miles = 2-1/2 cents/mile.
    phlack likes this.
  10. Boomer 2298
    36
    Edinboro, PA USA
    As an update I found something odd today, and hopefully one of the experienced members can shed some light on this. My commute is 10 miles on EV 50 on HV and 10 on EV. since I drive 70 - 80 mph for 50 the mileage drops accordingly plus studless snows and winter conditions a day after I drove it off the showroom lot. Today though I made a mistake on my way back home. I ran out the EV up to 18 miles. When I noticed I decided just to run it the 20 miles the meter showed (typical charge amount). So I left it in EV and the ICE kicked in at zero. Running about 75 MPH. So when I got to the to the exit I had to stop at the Walmart right off the exit. To my surprise as I pulled in with zero on the traction battery left it went full EV. So I drove in and parked. When I got back in the meter showed zero miles available. I tried to put it in EV and it said no charge available. I am in ECO mode. So, I took off slowly and to my surprise it was running full EV. In fact unless I gunned it it stayed in EV...for 10 more miles !??? No ICE except to go up a grade. Why would there be so much reserve and I am not able to see the true charge on the traction battery. Is there a way I can ?
  11. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I think you are confusing the part-time EV icon indicating the typical battery-run in HV mode with full-time EV mode. Perhaps what caused the confusion is also the fact that the Prime (as opposed to the regular Prius) is able to run off of the battery even past 42MPH, and you likely had the somewhat fluid HV portion of the traction battery pretty full when you got off the interstate resulting in a longer battery/EV run (as part of HV mode still) than usual.
  12. Boomer 2298
    36
    Edinboro, PA USA
    I was actually watching the status monitor and the IEC was not running at all. Just the traction battery. The EV icon was just added as additional information. I am aware the prime will run up to 82 mph on the battery as proven today. The engine like I said kicked in when the battery status showed zero miles left on the dime. When I got off the interstate and restarted it, it ran full EV (without the icon, wouldn't go in when button was pushed/ no charge) for 10 miles. No ICE except on a grade for a few seconds.
  13. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    When you are in hybrid mode and accelerating slowly, the traction battery will provide the power needed to move the car. If you had accelerated more aggressively it would have kicked in the ICE to supplement the electric motors.
    This behavior goes all the way back to the first Prius hybrids. In the 2002 models you could use the gas pedal gently to stay on battery only as you go from 0 to 25 MPH in about the length of a city block.
    On your car, the 0% battery is the EV portion of the battery. The car reserves the last XXX percent of the battery for Hybrid mode.
    Dan
    srivenkat likes this.
  14. Boomer 2298
    36
    Edinboro, PA USA
    With that said I could understand a little bit, but not a third of the reported capacity?
  15. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    It might help to put it in perspective this way. You did not go 10 miles on battery. The ICE was called upon when you encountered a grade and some of that power was fed back to the battery. The first 27(?) miles on EV would have included grades and acceleration.
    In general, the Prius does a good job of maximizing energy usage while minimizing emissions without any conscious efforts on the part of the driver. Since you will be able to charge at work, you will probably find that there is not a lot of difference between using the EV up front or using only when you are not on the highway. My 2002 Prius used to irk me because the engine would heat up for 5 minutes or more as soon as you started the car. But the first 5 minutes of my daily commute was stop signs, cross traffic and traffic signals. That was 5 minutes of idling even though I had a full battery. Ironically it would finish heating up just as I got to the freeway.
    If I were you I'd stop worrying about it. It's working as designed.
    Dan
    Henrik Helmers and srivenkat like this.
  16. Boomer 2298
    36
    Edinboro, PA USA
    Being a engineering kind of guy, I’m looking into it tomorrow. There was no way that the 14 seconds the ICE kicked on one time in 10 miles produced enough charge to take it that far. My background is in electronic VS drives and power production / process control. This did in fact run on EV for about 10 miles extra. I watch the odometer and gauge it as I am a metrics guy, happens when you become a director. Or maybe a engineering accountant lol Maybe that’s why I bought a PP. So, tomorrow I will run it out on EV to see if I can recreate the same situation. I will let you know. I haven’t started tearing into the electrical drawings and circuitry but give me time. Covid and all.
  17. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    When you do your test, make sure to include an altimeter so you can see the subtle down slopes that allow you to coast without realizing it. :)
    I'm no longer an engineer, but I'd start with whatever design documentation that can be found. Everything else should trace back to the designer's intentions. Design requirements that I recall hearing about:
    1) A percentage of the total battery capacity is reserved to avoid overcharging/overheating.
    2) A percentage of the remaining capacity is reserved to avoid over discharge.
    3) The "100%" on your dashboard really represents amount reserved for EV.
    4) The little battery graphic shows the "hybrid buffer" which should be the capacity not accounted for in 1-3.
    A good tool to use is Dr Prius which use an ODBII reader to give you the voltages of the battery.
    While you think that you are getting 10 miles of EV after the battery is depleted, I see that you are using the buffer that is normally used in HV mode to allow the battery to supplement the ICE. That buffer appears to be more generous than I thought it would be.
    In the original Prius design, (2000-2003) the battery was only 1.778 kWh. In that design the battery pack is normally charged between 40–60% of maximum capacity to prolong battery life as well as allow headroom for regenerative braking. Even so, I have traveled across town on battery power alone when the battery was fully charged. The more lights I hit the more likely I was to trigger the use of ICE.
    Dan
    srivenkat and jerrymildred like this.
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    @dbstoo makes an excellent point. I was going to ask about the slope. Even a nearly imperceptible downslope combined with lower speeds in the 30-40 mph range will produce prodigious miles/kWh numbers. Try taking that route again where you got the seemingly impossible EV distance in HV mode but make sure you have some EV range available so you can stay in EV mode (as opposed to HV with ICE off). Then watch the m/kWh gauge next to the speedometer. (If you don't have that enabled, it's in the meter customization screen in your MID settings.)
    By way of explanation, if you had time to brake gradually enough to keep the friction brakes out of play until the end of deceleration, slowing from 75 mph to a stop will regenerate over a mile of EV range and maybe more from that speed. Not enough to enable selecting EV mode, but enough to keep the ICE off for quite a while. Combine that with how far into the HV part of the battery the Prime can go before starting the ICE along with possibly a slight downward grade and it can astound you. I'm an engineer too (electronics) and former industrial electrician. And even for me, this car sometimes comes really close to being magical the way it can conserve energy.
    Henrik Helmers and phlack like this.
  19. srivenkat
    596
    93
    IL
    @dbstoo and @jerrymildred have done an excellent job trying to explain it. As they explain, it seems that the larger HV battery buffer (as compared to the regular Prius) being enough for the limited charge draw needed to go the 10 miles with likely a slight down grade, likely explains it. I still see value in limiting the battery to non-highway use since, per Toyota, one way to minimize battery degradation is to not use it at high speeds (perhaps they are talking 80+, but nonetheless).
    #19 srivenkat, Jan 28, 2021
    phlack likes this.
