New A/C blower... new Red Triangle with exclamation point
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryansb13, Mar 25, 2018.
  1. Ryansb13
    Ryansb13 New Member
    Thanks to everyone who has posted about replacing the A/C blower I was able to replace mine in my 2008 Prius... but once I finished the Red Triangle with exclamation came on and the screen said Problem.
    Anyone have any idea what I did to cause the red Triangle to come on?
    52,877
    not sure, did you disconnect the 12v and hybrid battery? how is the 12v health?
    does the blower work? is it new?
  3. Erik Owens
    Erik Owens Member
    162
    60
    If its the main blower that you have to remove the whole case then I would check to make sure you plugged everything back in and before you say you have I would check one more time.
  4. Ryansb13
    Ryansb13 New Member
    I did not disconnect either battery. The blower is new and works great.
    Do you think if I got the codes pulled it would show anything?
    Raytheeagle likes this.
  5. bisco
    52,877
    yes, but before doing that, disconnect the 12v negative for a few minutes to reset everything. if the triangle comes back, take it in.
    Ryansb13 likes this.
  6. Erik Owens
    Erik Owens Member
    162
    60
    Yes. Or at least give you a circuit to check which would more than likely help you along.
  7. Ryansb13
    Ryansb13 New Member
    I’ll do that... as far as I remember there were only two things I had to unplug.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    The codes will help you narrow down the next steps;).
    It could be something related to the AC or it could be something else. The codes will let you know(y).
  9. Ryansb13
    Ryansb13 New Member
    I disconnected the 12v battery for a few minutes and that cleared the red triangle. Thanks for the help.
