New A/c compressor replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Virgil Orly Dela Pena, Aug 15, 2025.
  1. Virgil Orly Dela Pena
    Virgil Orly Dela Pena Junior Member
    Las Vegas Nevada USA
    I recently purchased a rebuilt A/C compressor from Four Seasons for my second-generation Prius and am unsure where to add the hybrid-grade oil. The compressor requires approximately 4.9 oz, but when I tried filling through the drain bolt, it only accepted about 3 oz. The low-side service port can accommodate the full 4.9 oz, yet when I add oil there, it doesn’t flow through to the drain bolt—and vice versa. It appears the two fill points are completely isolated from each other. Should I be distributing the oil between both ports?
  2. Tombukt2
    Tombukt2 Senior Member
    13,802
    2,504
    Durham NC
    4.9 is full system you got a bit on condenser lines etc I wouldn't drop that whole amount I don't think . Wen I do reg Denso belt a/c I add about 1 ounce as a general rule . To mix with what's inside the rest of system . Unless replacing most hard parts condenser EVAP in car etc . Most are not replacing all that . I could be doing it wrong I have no idea I know once Ireplace a compressor on a Corolla I generally don't again . I've got 25 yr old Corollas w ice cold air running Enviro temp refrigerant from the 90's still freezing.
  3. Tombukt2
    13,802
    2,504
    Durham NC
    Member there's no hi and low sides till compressor pumps the system up . So hi and lo ports are same . Until
