New ABS booster issue
Discussion in 'Gen 3 Prius Technical Discussion' started by ducktor1, May 7, 2022.
  1. ducktor1
    ducktor1 New Member
    virginia
    I just had my brake master cylinder and ABS pump assembly replaced and the new pump is buzzing every 5 seconds or so. Is this typical for a newly installed ABS pump?
  2. JC91006
    16,936
    8,647
    it should be the exact same thing as your old one. The noise is not normal.
    Did you replace with a new part or used part? If it's used, it's just a failed part that was installed
  3. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Normal, it it's leaking. But with new parts, no.
    Take it back and have them do it correctly. Were the parts new or used?
    They SHOULD have checked that BEFORE even calling you to tell you it's completed.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,063
    6,933
    Texas Hill Country
    If the parts and mechanical installation are good, it needs a special Techstream bleed procedure that goes beyond a regular brake bleed.
